I wanted to build an example app using ReactJS and JS API 4.x with ES Modules.
I followed few examples provided by ESRI as below,
1. https://github.com/odoe/jsapi-react-template
2. https://github.com/Esri/nearby-javascript
3. https://github.com/odoe/esrijs4-vm-react
4. https://github.com/Esri/react-arcgis
But I'm not able to get it, coz each one is following different approaches.
Even I tried by requesting a case with ESRI technical team, but I didn't received a proper solution.
So, can I get any exmaple source so that I can get clear knowledge How to add the Map and a FeatureLayer with ES Modules using React core and Reacthooks.
Regards,
Valgen Map
