TimeSlider console error with ArcGIS JS API 4.13
1559
10-21-2019 12:06 PM
RoelGarcia
Hello,
I am using the ArcGIS JS API 4.13 and I am getting this console error from the time slider widget. This error is causing that the time slider widget does not show up.
If anyone knows how can I resolve that issue, please let me know.
Thank you,
Roel
Tags (1)
Noah-Sager
Do you have a container defined for the TimeWidget?
test app
https://codepen.io/noash/pen/XWWpeMB
BenElan
Hi Roel,
Would it be possible for you to post your code so I can take a closer look?
Thanks
RoelGarcia
Hi Ben,
Attached is the TimeSlider widget code..
Roel
Noah-Sager
test app
RoelGarcia
Hi Noah,
Adding a container fixed the issue!!
Roel
