I'm using the sketch widget to draw a point, line, ... with capture enabled on a feature layer.
This feature layer is branch versioned, gdbVersion and historicMoment are properly set : I can see the latest geometry updates on that layer.
Unfortunately, the snapping does not take into account current historic moment : the snapping on modified object uses the initial unmodified geometry shape.
I can easily reproduce on sandbox https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=sketch-geometries.
Is this a bug ? Is there a way to snap on the most up-to-date geometries ?
Thanks in advance.
Jean-Luc
