I'm trying to create an add data widget with csv input.
using the shapefile to feature Layer sample as a base.
https://developers.arcgis.com/javascript/latest/sample-code/layers-featurelayer-shapefile/
the sample uses generate, and for the publishing parameters Analyze.
"Callers can use the Analyze operation to generate the default publishing parameters for the source input."
https://developers.arcgis.com/rest/users-groups-and-items/generate.htm
I have a 1 point csv for testing. - attached
the analyze works, but i think I'm not using the generate properly because I'm getting "414 Request-URI Too Large error" on such a small table.
I believe the generate should return an object to automatically work with the addShapefileToMap.
<!DOCTYPE html>
<html lang="en" >
<head>
<meta charset="UTF-8">
<title>CodePen - Create a FeatureLayer from a shapefile almost there</title>
</head>
<body>
<!-- partial:index.partial.html -->
<html lang="en">
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>
Create a FeatureLayer from a shapefile | Sample | ArcGIS Maps SDK for
JavaScript 4.27
</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#mainWindow {
padding: .5em;
background-color: #fff;
#mainWindow p, #uploadForm {
display: block;
padding: .1em;
</style>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.27/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.27/"></script>
<script>
require([
"esri/config",
"esri/Map",
"esri/views/MapView",
"esri/widgets/Expand",
"esri/request",
"esri/layers/FeatureLayer",
"esri/layers/support/Field",
"esri/Graphic"
esriConfig,
Map,
MapView,
Expand,
request,
FeatureLayer,
Field,
Graphic
const portalUrl = "https://www.arcgis.com";
document
.getElementById("uploadForm")
.addEventListener("change", (event) => {
const fileName = event.target.value.toLowerCase();
generateFeatureCollection(fileName);
const map = new Map({
basemap: "dark-gray-vector"
const view = new MapView({
center: [-41.647, 36.41],
zoom: 2,
map: map,
container: "viewDiv",
popup: {
defaultPopupTemplateEnabled: true
const fileForm = document.getElementById("mainWindow");
const expand = new Expand({
expandIcon: "upload",
view: view,
content: fileForm
view.ui.add(expand, "top-right");
function generateFeatureCollection(fileName) {
let name = fileName.split(".");
// Chrome adds c:\fakepath to the value - we need to remove it
name = name[0].replace("c:\\fakepath\\", "");
document.getElementById("upload-status").innerHTML =
"<b>Loading </b>" + name;
// define the input params for generate see the rest doc for details
// https://developers.arcgis.com/rest/users-groups-and-items/generate.htm
const params = {
targetSR: view.spatialReference,
maxRecordCount: 1000,
enforceInputFileSizeLimit: true,
enforceOutputJsonSizeLimit: true
// generalize features to 10 meters for better performance
params.generalize = true;
params.maxAllowableOffset = 10;
params.reducePrecision = true;
params.numberOfDigitsAfterDecimal = 0;
let myContent = {
filetype: "csv",
publishParameters: JSON.stringify(params),
f: "json"
////////////////////////////// analyze csv
request(portalUrl + "/sharing/rest/content/features/analyze", {
query: myContent,
body: document.getElementById("uploadForm"),
responseType: "json"
.then((response) => {
console.log("analyze")
console.log(response);
////////create new query for generate with response from analyze
let myContent = {
filetype: "csv",
publishParameters: JSON.stringify(response.data.publishParameters),
f: "json"
/////////////////////////////////////generate
request(portalUrl + "/sharing/rest/content/features/generate", {
//method:"post",
query: myContent,
body: response.data.records,
console.log("generate")
const layerName = response.data.publishParameters.name;
//response.data.featureCollection.layers[0].layerDefinition.name;
"<b>Loaded: </b>" + layerName;
addShapefileToMap(response.data);
.catch(errorHandler);
///////////////////////////////////////////// all this inside then
function errorHandler(error) {
console.log(error.message)
"<p style='color:red;max-width: 500px;'>" + error.message + "</p>";
function addShapefileToMap(featureCollection) {
console.log("adding layer")
// add the shapefile to the map and zoom to the feature collection extent
// if you want to persist the feature collection when you reload browser, you could store the
// collection in local storage by serializing the layer using featureLayer.toJson()
// see the 'Feature Collection in Local Storage' sample for an example of how to work with local storage
let sourceGraphics = [];
const layers = featureCollection.layers.map((layer) => {
const graphics = layer.featureSet.features.map((feature) => {
return Graphic.fromJSON(feature);
sourceGraphics = sourceGraphics.concat(graphics);
const featureLayer = new FeatureLayer({
objectIdField: "FID",
source: graphics,
fields: layer.layerDefinition.fields.map((field) => {
return Field.fromJSON(field);
return featureLayer;
// associate the feature with the popup on click to enable highlight and zoom to
map.addMany(layers);
view.goTo(sourceGraphics).catch((error) => {
if (error.name != "AbortError") {
console.error(error);
document.getElementById("upload-status").innerHTML = "";
</script>
</head>
<body>
<div id="mainWindow">
<div>
<div style="padding-left:4px;">
<p>
Download shapefile from
<a
href="https://bsvensson.github.io/various-tests/shp/drp_county_boundary.zip"
>here.</a
</p>
<p>Add a zipped shapefile to the map.</p>
<p>
Visit the
<a
target="_blank"
href="https://doc.arcgis.com/en/arcgis-online/reference/shapefiles.htm"
>Shapefiles</a
help topic for information and limitations.
</p>
<form enctype="multipart/form-data" method="post" id="uploadForm">
<div class="field">
<label class="file-upload">
<span><strong>Add File</strong></span>
<input type="file" name="file" id="inFile" />
</label>
</div>
</form>
<span
class="file-upload-status"
style="opacity:1;"
id="upload-status"
></span>
<div id="fileInfo"></div>
</div>
</div>
</div>
<div id="viewDiv"></div>
</body>
</html>
<!-- partial -->
</body>
</html>
