Need to show map coordinates in div...
2566
05-26-2015 09:27 AM
CharlesGage
Been away from Javascript api for a long time.  Things have really changed and I cannot find my way around anymore.  I need a sample of code that shows how to display the map coordinates when moving the cursor over a map.  Any ideas?
BTW, this new forum feels like Facebook more than a forum.  Not sure I like it.
RickeyFight
MVP Regular Contributor
RebeccaStrauch__GISP
Here's a good place to start when trying to get back into the JavaScript API
ArcGIS API for JavaScript
I think that is where the sample Rickey mentions came from, but couldn't find it right off.
I would suggest looking at the  Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers And if looking there, check out my resource list for it  Web AppBuilder Developer Edition – Customization Resource List   to find help geting started and installed, many samples, custom widgets, etc.    One thing to note, it requires a ArcGIS Online or Portal for ArcGIS access to get started.
re: GeoNet.  I was reluctant at first for the same reason (i.e. social media look) but it it a very good and very active platform.  You can customize it to get as much or little info sent to you as you want.  Worth giving it a chance.  My opinion.
