Move Graphic in FeatureLayer to new coordinates
292
08-18-2022 04:59 AM
quooston
New Contributor III
Hello,
I am using version 4.24.
I have a FeatureLayer and I'm providing Features to it on the client-side. I construct Graphics for the coordinates returned from my application API, and put them on a map. When I hit my API after the initial and successful operation, which instantiates the FeatureLayer and provides it it's initial source (the collection of features I have constructed on the client), I would like to update the coordinates of those features on the map whenever I request an update from my API.
My assumption was that I could use `featureLayer.applyEdits` and pass along the updated features, but nothing happens. The result of that operation states that X items were updated, but the map does up change (the features remain stationary). I have also tried to delete features using `featureLayer.applyEdits` with the `deletedFeatures`... but with the same result. The result states that X items were deleted... but they're still on the map.
Before I start removing everything to put it back at new coordinates, I thought I would check to see if there is something wrong with my approach. I would hate to be removing thousands of features and putting them back, just to update their coordinates, on a regular basis.
I was able to achieve this very easily using Leaflet and MapBox previously, so I'm sure I must be missing something here...
Thanks in advance for any assistance.
AnneFitz
quooston
New Contributor III
I am now able to remove Features using `applyEdits` and `deletedFeatures`, but I am still not able to update the coordinates of the Features.
The mistake I made was that I was specifying a custom attribute as the `objectId`, but it was a guid. No errors were reported and my Features were rendering successfully, but the custom attribute (in my case a guid) was not appropriate for `applyEdits`. By adding another attribute with a type of  `oid`, I am now able to delete the features.
I'm starting to wonder if updates are limited to attributes and not the geometry of the Graphic...
quooston
New Contributor III
I am now able to delete, and then add new Features to get what I want. I will look into the the updateFeatures again later on and update this thread for those who are interested.
AnneFitz
Here's an example showing how you can update feature geometries using applyEdits: https://codepen.io/annefitz/pen/jOzXQxv?editors=100
quooston
New Contributor III
Thanks @AnneFitz 🙂
It's good to know that this is possible. I think querying the features and then updating them as you have done here is better. I have been trying to do the update by creating a feature and setting the objectId and then providing the updated geometry. Something there has been off, as I experienced with the delete comment above.
Thanks again
