I am trying to set the following properties on the view (arcgis api 4.5)
effectiveMinZoom
effectiveMaxZoom.
So that I can set the max and min allowed zoom level . For some reason I don't see any errors and the min and max zoom levels are not set.
I also tried minZoom and maxZoom. No luck
Here is my code :
var map = new Map({
basemap: "hybrid"
// map.add(transportationLyr);
var view = new MapView({
container: "viewDiv", // Reference to the DOM node that will contain the view
map: map, // References the map object created in step 3
zoom: 12,
effectiveMaxZoom: 15,
effectiveMinZoom: 10,
center: [-82.78,35.0],
padding:{
right:320
