Francesco,
Just change the esriRequest url to yours and this should work:
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>PHP WebService Smaple</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.13/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.13/esri/css/esri.css">
<style>
html, body, #map {
height:100%;
width:100%;
margin:0;
padding:0;
body {
background-color:#FFF;
overflow:hidden;
font-family:"Trebuchet MS";
.esriSimpleSliderHomeButton {
border-bottom: 2px solid #666666;
background-image: url(images/home.png);
background-repeat: no-repeat;
background-position: center;
cursor: pointer;
.esriSimpleSliderHomeButton:hover {
background-color: rgb(238, 238, 238);
background-color: rgba(238, 238, 238, 0.9);
</style>
<script src="//js.arcgis.com/3.13/"></script>
<script>
var map;
require([
"esri/map", "esri/geometry/Point", "esri/symbols/SimpleMarkerSymbol",
"esri/graphic", "esri/layers/GraphicsLayer", "esri/request", "dojo/parser",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dojo/domReady!"
], function(
Map, Point, SimpleMarkerSymbol,
Grahpic, GraphicsLayer, esriRequest,
parser
parser.parse();
map = new Map("map", {
basemap: "streets",
center: [10.740, 43.335],
slider: true,
zoom: 16
dojo.connect(map,"onLoad",function(){
var initExtent = map.extent;
dojo.create("div",{
className: "esriSimpleSliderHomeButton",
title: 'Zoom to Full Extent',
onclick: function(){
map.setExtent(initExtent);
},dojo.query(".esriSimpleSliderIncrementButton")[0], "after");
var gl = new GraphicsLayer({ id: "Sites" });
map.addLayer(gl);
var locsRequest = esriRequest({
url: "francisco.json", /*change this*/
handleAs: "json"
var graphic;
locsRequest.then(
function(response) {
var j = 0;
for (var i = 0; i < response.length; i++) {
j++;
if (j >=9) {j = 1};
graphic = new Grahpic(new Point(response.X,response.Y), new SimpleMarkerSymbol());
var siteid = 'site' + i;
gl.add(graphic);
}, function(error) {
console.log("Error: ", error.message);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit/layout/BorderContainer"
data-dojo-props="design:'sidebar', gutters:false"
style="width:100%;height:100%;">
<div id="map"
data-dojo-type="dijit/layout/ContentPane"
data-dojo-props="region:'center'">
</div>
</div>
</body>
</html>
