Hi, guys.
I have got the extent of the map view from its extent property. As I need to load the data async from the backend when the user drags the map, so every time after user drag and stops, I need to send an API to the backend, which takes the current map lat/long on the four corners of the screen to the params of the API. I find the extent of the Mapview property, but its format is different from the lat/long. Is there any way or API to get the suitable lat/long of the four corners of the screen on the map?
Thank you.
