I am unable to create the exact your use case, but tried with point creation.
Popup is coming with exact latitude and longitude for each point I have clicked.
Screen shot enclosed.
<html>
<head>
<meta charset="utf-8" />
<meta
name="viewport"
content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>Draw polyline | Sample | ArcGIS API for JavaScript 4.24</title>
<link
rel="stylesheet"
href="https://js.arcgis.com/4.24/esri/themes/light/main.css"
<script src="https://js.arcgis.com/4.24/"></script>
<style>
html,
body,
#viewDiv {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
</style>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/views/draw/Draw",
"esri/Graphic",
"esri/views/draw/PointDrawAction",
"esri/widgets/Popup",
], (Map, MapView, Draw, Graphic, PointDrawAction, Popup) => {
const map = new Map({
basemap: "gray-vector",
const view = new MapView({
container: "viewDiv",
map: map,
zoom: 15,
center: [75, 14],
view.ui.add("point-button", "top-left");
const draw = new Draw({
view: view,
document.getElementById("point-button").onclick = () => {
const action = draw.create("point");
view.focus();
action.on(["draw-complete"], updateVertices);
function updateVertices(event) {
if (event.coordinates.length > 1) {
const result = createGraphic(event);
function createGraphic(event) {
let point = {
type: "point",
x: event.coordinates[0],
y: event.coordinates[1],
spatialReference: view.spatialReference,
let graphic = new Graphic({
geometry: point,
symbol: {
type: "simple-marker",
style: "circle",
color: "red",
outline: {
color: [255, 255, 0],
width: 3,
view.graphics.add(graphic);
showPopup(graphic);
function showPopup(graphic) {
console.log(
graphic.geometry.latitude + " - " + graphic.geometry.longitude
view.popup.open({
content: `<b>latitude: ${graphic.geometry.latitude} <br/> latitude: ${graphic.geometry.longitude}<b>`,
</script>
</head>
<body>
<div id="viewDiv">
<div
id="point-button"
class="esri-widget esri-widget--button esri-interactive"
title="Draw Point"
<span class="esri-icon-map-pin"></span>
</div>
</div>
</body>
</html>
