Please help me if you can,
I'm getting the following message in the console ...
Map: Geometry (wkid: 102685) cannot be converted to spatial reference of the map (wkid: 102100)
Similar to this thread
https://community.esri.com/thread/66936
I also found this one which appears related
Map options: issues with non-mercator spatial reference
I tried using the suggestion by Adam Skoog in that first thread (66936) but when I get to what shows up as line # 07. In his code, I get an error as follows:
Uncaught TypeError: Cannot read property 'spatialReference' of undefined
Which seems odd since all of this is inside a require block that includes Map, ProjectParameters, SpatialReference, Extent, Geometry, GeometryService etc. etc.
My code looks like this
esriConfig.defaults.io.proxyUrl = "/proxy";
esriConfig.defaults.io.alwaysUseProxy = false;
esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
// I have xMin, xMax, yMin, yMax sent in to this php file and it seems I need the Number() fx to get real numbers
// This prints the following to the console ...
// -8819410.666559163 4792613.494165327 -8813596.67509507 4794481.424044095 pmeasure.js:50
// -8816503.670827117 4793547.459104711 pmeasure.js:51
// AND IF THE BLOCK STARTING WITH "var defer = " IS UNCOMMENTED, I GET THIS
// Uncaught TypeError: Cannot read property 'spatialReference' of undefined
var avgX = ((Number(xMin) + Number(xMax)) / 2);
var avgY = ((Number(yMin) + Number(yMax)) / 2);
console.log(xMin, yMin, xMax, yMax);
console.log(avgX, avgY);
var passedExtent = new esri.geometry.Extent(Number(xMin), Number(yMin), Number(xMax), Number(yMax), new esri.SpatialReference({wkid:102685}) );
var projectParams = new esri.tasks.ProjectParameters();
projectParams.geometries = passedExtent;
projectParams.outSR = new esri.SpatialReference({wkid:102100}); // map.spatialReference; ummmmm map not defined yet
projectParams.spatialReference = new esri.SpatialReference({wkid:2248}); // map.spatialReference;
// var defer = esri.config.defaults.geometryService.project(projectParams);
// dojo.when(defer, function (projectedGeometry) {
// if (projectedGeometry.length > 0) {
// map.setExtent(projectedGeometry[0]);
map = new Map("map", {
basemap: "streets",
center: [avgX, avgY], // center: [-79.23, 39.51],
extent: passedExtent,
zoom: 12
