FeatureLayer modes (MODE_SELECTION and MODE_ONDEMAND) for JS 4.x
496
7
09-13-2024 10:03 AM
Mr_Kirkwood
I am new to the JS 4.x language. The JS 3.x had the modes. These helped with queries where you could zoom into a FeatureLayer  and have it turn on when zoomed to. The Featurelayer doesnt show up when using MODE_SELECTION until it was queried and selected. Here is an exapmple of the 3.x code:
floorOutline = new FeatureLayer (urlFloorOutline, {
                    mode: FeatureLayer.MODE_SELECTION,
                    outFields: ["*"],
                    opacity: 0.8,
This was added t othe map and did not show up on the map until you ran the zoom to fucntion:
function zoomFloorOutline (id)
    require ([
        "esri/tasks/query",
        "esri/geometry/ScreenPoint",
        "esri/geometry/Extent",
        "esri/layers/FeatureLayer"
            function (Query, ScreenPoint, Extent, FeatureLayer)
                console.log ("zoomFloorOutline")
                clearGraphics ();
                var query = new Query ();
                query.objectIds = [id];
                var myDate = new Date ();
                var myMS = myDate.getMilliseconds ();
                query.where = "(" + myMS + "=" + myMS + ")";
                console.log ("zoomFloorOutline + id")
                floorOutline.selectFeatures (query, FeatureLayer.SELECTION_NEW, function (features)
                    var floorExtent = features[0].geometry.getExtent ().expand (1.5);
                    map.setExtent (floorExtent);
How do i do something similar with JS 4.x?  I have some code to zoom to the feature but it is visible when the map is loaded and i just want show the quereied floor.
    require ([
        "esri/rest/query",
        "esri/rest/support/Query",
        "esri/layers/FeatureLayer",
       "esri/views/layers/LayerView"
            function (query, Query, FeatureLayer,LayerView)
                console.log ("zoomFloorOutline");
//                let highlight;
                view.whenLayerView (floorOutline).then (function (layerView)
                    var query = floorOutline.createQuery ();
                    query.where = "1=1";
                    floorOutline.queryFeatures (query).then (function (results)
                        const features = results.features;
                        console.log("zoom Floor" + features)
                        var geometry = features[0].geometry.extent.clone ().expand (2);
                        view.goTo (geometry);
Thanks for any help.
JoelBennett
MVP Regular Contributor
On line 25 of your 4.x code you have this to zoom to the feature:
If you want to make the layer visible after zooming, you can change that line to the following:
view.goTo(geometry).then(function() {
	floorOutline.visible = true;
JoelBennett
If you're just wanting to show a particular set of features at any given time, and know the objectID values of that set, then using definitionExpression would be one way to do so:
function hideLayerFeatures(featureLayer) {
	featureLayer.definitionExpression = "1=0";
function showLayerFeatures(featureLayer, ids) {
	if (Array.isArray(ids))
		featureLayer.definitionExpression = featureLayer.objectIdField + " IN(" + ids.join(",") + ")";
	else if (typeof ids == "number")
		featureLayer.definitionExpression = featureLayer.objectIdField + " = " + ids.toString();
Mr_Kirkwood
I already have some code to grab the OBJECTID. How do I get the layer to turn on to the queried OBJECTID when I zoom to the Feature? I have set the visibility for the whole layer to "false"
JoelBennett
Mr_Kirkwood
That worked. Thank you so much for your help.
Mr_Kirkwood
Thanks again. Here is my updated code snippet:
    require ([
        "esri/rest/query",
            function (query, Query, FeatureLayer, LayerView)
                floorOutline.definitionExpression = floorOutline.objectIdField + " = " + id.toString ();
                console.log (floorOutline.definitionExpression)
                        view.goTo (geometry).then (function ()
How would this work with an array of OBJECTIDs? My JS 3.x looks like this:
function zoomRoomUse (ids)
    require ([
        "esri/tasks/query",
            function (Query, Extent, FeatureLayer)
                console.log ("zoomRoomUse")
                query.objectIds = ids;
                roomUseLayer.selectFeatures (query, FeatureLayer.SELECTION_NEW, function (features)
                    var newExtent = new Extent ();
                    newExtent = features[0].geometry.getExtent ();
                    for (var k = 0; k < features.length; k++) {
                        newExtent = newExtent.union (features[k].geometry.getExtent ().expand (15));
                    labelRoom ();
I am having trouble updating it to 4.x
Mr_Kirkwood
I tried something like this:
    require ([
        "esri/rest/query",
                roomsUseLayer.definitionExpression = roomsUseLayer.objectIdField + " IN(" + ids.join(",") + ")";
                console.log (roomsUseLayer.definitionExpression)
                console.log(ids)
                view.whenLayerView (roomsUseLayer).then (function (layerView)
                    var query = roomsUseLayer.createQuery ();
                    query.objectIds = [ids];
                    roomsUseLayer.queryFeatures (query).then (function (results)
                        var geometry = features[0].geometry.extent.clone ();
                            geometry = geometry.union (features[k].geometry.extent.clone ());
                                roomsUseLayer.visible = true;
JoelBennett
On line 21, instead of:
I think you need this instead:
query.where = roomsUseLayer.definitionExpression;
Or better yet, you could remove line 21 altogether, because according to the documentation for createQuery, the "where" setting should already be set according to the definitionExpression.  Setting it to "1=1" would overwrite that and return all features in the layer.
