FeatureLayer from FeatureCollection
5390
15
12-15-2015 05:53 PM
LefterisKoumis
Occasional Contributor III
I get the Converting circular structure to JSON error when I create the feature layer, thislayer. Any ideas? Thank you..
var requestHandle = esriRequest({
            "url": myurl, //I set the variable to a featureservice url
            "content": {
              "f": "json"
            "callbackParamName": "callback"
          myfields =requestHandle.then(this.requestSucceeded, this.requestFailed);
   var layerDefinition = {
        "geometryType": "esriGeometryPoint",
        "fields": myfields,
         "objectIdField": "OBJECTID",
  var featureCollection = {
  layerDefinition: layerDefinition,
  featureSet: myfeatureSet  //it's derived from a query
  var thislayer = new esri.layers.FeatureLayer(featureCollection, {
        mode: FeatureLayer.MODE_SNAPSHOT,
  outFields:["*"]}
  this._openResultInAttributeTable(thislayer);
      requestSucceeded:function(response, io){
            fields = array.map(response.fields);
  return fields;
        requestFailed: function(error, io){
  console.log("got an error");
RobertScheitlin__GISP
Lefteris,
  Your code was a mess. You need to spend more time cleaning up your code so you don't get confused in there. Here is a pretty clean working version.
LefterisKoumis
I modified it but still get the same error.
  mapServiceUrl= <map service>;
            "url": dojo.replace("{0}/layers",[mapServiceUrl]),
            "content": {
              "f": "json"
       requestHandle.then(lang.hitch(this, function(response){
  dojo.forEach(response.layers, function(layerInfo) {
              console.log(layerInfo); //checking layer name
            if(layerInfo.fields) {
              dojo.forEach(layerInfo.fields, function(fieldInfo) {
  console.log(fieldInfo); //checking fields
  myfields =layerInfo.fields;
          "layerDefinition": null,
          "featureSet": {
            "features": [],
  layerDefinition = {
          "objectIdField": "ObjectID",
   "field": [myfields]
  featureSet: featureSet
  var thislayer = new esri.layers.FeatureLayer(featureCollection);
Lefteris,
  Something more like this:
var mapServiceUrl = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/M..." ;
var thislayer = null, featureCollection = null;
esriRequest({
  url: mapServiceUrl,
  content: {
    f: 'json'
  handleAs: 'json',
  callbackParamName: 'callback'
}).then(lang.hitch(this, function (layerInfo) {
    layerDefinition: layerInfo,
    featureSet: null
  thislayer = new FeatureLayer(featureCollection);
LefterisKoumis
Thank you.
It seems that the featureSet was causing the error. But how do I define the new layer based on the query selection. By defining the  featureSet: null then the selection is null.
Also, when I pass on thislayer to the _openResultInAttributeTable function, I get the error that it cannot read the 'name' of undefined even though the currentlayer is not null!
_openResultInAttributeTable: function (currentLayer) {
        var aLayer = {
          layerObject: currentLayer,
          title: currentLayer.name,
          getLayerObject: function () {
            var def = new Deferred();
            if (this.layerObject) {
              def.resolve(this.layerObject);
            } else {
              def.reject("layerObject is null");
Lefteris,
  The code provided in my last reply will setup the FeatureLayer (only the shell) for you then you have to add features to it (as I do in the eSearch). The name is null because you have not defined it yet. you should notice that I set several properties to the layerInfo once I receive it:
layerInfo.name = this.nls.search + ' ' + this.nls.results + ': ' + layerConfig.name;
layerInfo._titleForLegend = layerInfo.name;
layerInfo.minScale = 0;
layerInfo.maxScale = 0;
layerInfo.effectiveMinScale = 0;
layerInfo.effectiveMaxScale = 0;
layerInfo.defaultVisibility = true;
LefterisKoumis
Sorry to drag it on, but it is confusing. Why do I need to assign a name to the layerinfo when it already has it?
I verified it by using the code below. So by declaring
in the featurecollection the name should be passed on as well since I will use the same layerinfo for the new featurelayer as the myurl. However it is not passed on when a featurelayer is created using that feature collection. What am I  missing here? Thank you for your patience.
  esriRequest({
  url: myurl,
  content: {
  f: 'json'
  handleAs: 'json',
  console.log(layerInfo.name);  //name is printed in console
Lefteris,
   I really have no idea then. As always working with portions of code is difficult as I have to assume how you are handling other parts.
LefterisKoumis
Ok. I didn't want to post a long script. I will create a smaller version of it and test it again. If still has problems, I will post it Thank you for your commitment helping others.
Lefteris,
   You can always zip the widget and then attach the zip using the advanced editor.
LefterisKoumis
Ok. Here you go.
The ultimate goal is to pass on the thislayer to the _openResultInAttributeTable so it can publish the table with the query results. As you can see from the line 276, the layer has the layer name, however the _openResultInAttributeTable cannot access it. The second issue is how to pass on the featureSet of the quesry results to the feature collection. When I including it it causes the Converting circular structure to JSON error.
Thank you.
