UPDATE 7/10/2018
In case anyone was curious, I managed to get the video feed working by using the code below. The only issue I noticed is that every time it updates the feed using the setInterval function, the picture flashes as its being updated. A little annoying and not sure how to get around that.
Thank you! -Laura
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<link rel="stylesheet" href="https://js.arcgis.com/3.24/dijit/themes/soria/soria.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.24/esri/css/esri.css">
<style>
html,
body,
#mapDiv {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
body {
background-color: #FFF;
overflow: hidden;
font-family: "Trebuchet MS";
</style>
<script src="https://js.arcgis.com/3.24/"></script>
<script>
var atInspContent, videoContent;
var map, updateFeature, cameras;
require([
"dojo/dom-construct",
"esri/map",
"esri/dijit/InfoWindow",
"esri/layers/FeatureLayer",
"esri/InfoTemplate",
"esri/tasks/query",
"esri/dijit/AttributeInspector",
"esri/config",
"dojo/number",
"dojo/on",
"dijit/layout/TabContainer",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/form/Button",
"dojo/domReady!"
function (
domConstruct, Map, InfoWindow, FeatureLayer, InfoTemplate, Query, AttributeInspector,
esriConfig,
number, on,
TabContainer, BorderContainer, ContentPane, Button
//infoWindow: Creation
var infoWindow = new InfoWindow({}, domConstruct.create("div"));
infoWindow.startup();
//Map: Creation
var map = new Map("mapDiv", {
basemap: "topo",
center: [-96.755, 33.176],
zoom: 20,
infoWindow: infoWindow
//infoTemplate: Creation
var infoTemplate = new InfoTemplate();
infoTemplate.setTitle("${CAMERA_NAME}");
infoTemplate.setContent(setWindowContent());
//Layer: Creation
var cameras = new FeatureLayer("MY_CAMERA_URL", {
mode: FeatureLayer.MODE_SNAPSHOT,
infoTemplate: infoTemplate,
outFields: ["*"]
//Map & infoWindow: Actions
//when the camera layer is added to the map, the Attribute Inspector tool (TAB 2) is initialized
map.on("layers-add-result", initSelectToolbar);
//adds camera layer to map
map.addLayers([cameras]);
//resizes the infoWindow
map.infoWindow.resize(450, 410);
//infoWindow Container: Creation
function setWindowContent(evt) {
//makes a container for tabs
var tc = new TabContainer({
style: "height: 100%; width: 100%;"
}, dojo.create("div"));
//creates tab 1
videoContent = new ContentPane({
title: "Video"
tc.addChild(videoContent);
//creates tab 2
atInspContent = new ContentPane({
title: "Edit"
tc.addChild(atInspContent);
return tc.domNode;
//infoWindow TAB 1: Gets the camera video feed--------------------------------------------------------//
function getVideo(evt) {
cameraURL = evt.attributes.URL;
setInterval(function () {
//assigns the selected camera url to the src attribute of the html iframe
document.getElementById('video').src = cameraURL;
//sets the cadence for refreshing the image - in this case it's every 1 second
}, 1000);
return document.getElementById('video');
//infoWindow TAB 2: Gets the Attribute Inspector tool--------------------------------------------------//
function initSelectToolbar(evt) {
var selectQuery = new Query();
map.on("click", function (evt) {
selectQuery.geometry = evt.mapPoint;
selectQuery.distance = 4;
selectQuery.units = "feet"
selectQuery.returnGeometry = true;
selectQuery.outSpatialReference = map.spatialReference;
cameras.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function (features) {
if (features.length > 0) {
updateFeature = features[0];
map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
videoContent.setContent(getVideo(features[0]));
} else {
map.infoWindow.hide();
//infoWindow: Action
map.infoWindow.on("hide", function () {
cameras.clearSelection();
//Editable Fields: Configuration
var layerInfos = [{
'featureLayer': cameras,
'showAttachments': false,
'isEditable': true,
'fieldInfos': [{
'fieldName': 'CAMERA_NAME',
'label': 'Name',
'isEditable': false
'fieldName': 'VideoStream',
'label': 'Video Stream?',
'isEditable': true
'fieldName': 'CorrectView',
'label': 'Correct View?',
'isEditable': true
'fieldName': 'Comments',
'label': 'Comments',
'isEditable': true
//Attribute Inspector: Initialize
var attInspector = new AttributeInspector({
layerInfos: layerInfos
//Attribute Inspector: Adds save button next to delete button
var saveButton = new Button({
label: "Save",
"class": "saveButton"
domConstruct.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after");
//Save Button: Action
saveButton.on("click", function () {
updateFeature.getLayer().applyEdits(null, [updateFeature], null);
//Attribute Inspector: Adds close button next to save button
var closeButton = new Button({
label: "Close",
"class": "closeButton"
domConstruct.place(closeButton.domNode, saveButton.domNode, "after");
//Close Button: Action
closeButton.on("click", function () {
//Attribute Inspector: Action
attInspector.on("attribute-change", function (evt) {
//stores the updates to apply when the save button is clicked
updateFeature.attributes[evt.fieldName] = evt.fieldValue;
attInspector.on("next", function (evt) {
updateFeature = evt.feature;
atInspContent.setContent(attInspector.domNode);
</script>
</head>
<body class="soria">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width: 100%; height: 100%; margin: 0;">
<div id="mapDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'censater'">
</div>
</div>
<iframe id="video" width="400" height="330" frameborder="0" src="">
</iframe>
</body>
</html>
