As I continued to search for a solution to this issue, I came across an older post and a solution by @RobertScheitlin__GISP that does, more or less, what I want. However, it was written for 3.23. I am trying to get it to week with 4.22, though, because it will be part of a larger project that is otherwise functioning well.
In a nutshell, I would like to use the search widget to perform a search and query a feature layer based on the results of this search. For instance, say I have a PLSS layer and when one enters an address or set of coordinates, the PLSS layer is queried at that search location and the pop-up returns the PLSS attributes associated with that location.
I hope to solve this first, but to add a little more complexity to the issue, I am actually searching multiple sources. Searching by multiple layer sources works great when the appropriate search term is entered (e.g. township, range, and section) information, but I essentially want a reverse geocode type solution in which someone types an address or enters coordinates and the PLSS layer is queried at that location and those results are returned.
At issue (among many other things) is I am not particularly savvy when it comes to JS. I can take others' code and modify it to my needs, but that is the extent of it--so I basically need a lot of handhold.
Below is the code I have working that includes everything except the spatial query. The feature layers I am using in it are just place holders and are not the ones I will actually be using going forward (so the attributes that pop up are a bit nonsensical at the moment).
<html>
<head>
<meta name="description" content="DevLav: Query a feature layer">
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>PLSS Coordinate Calculator</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.esri-view:fullscreen {
background-color: #fff;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.22/esri/css/main.css">
<script src="https://js.arcgis.com/4.22/"></script>
</head>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/widgets/CoordinateConversion",
"esri/layers/GroupLayer",
"esri/layers/FeatureLayer",
"esri/layers/MapImageLayer",
"esri/widgets/Home",
"esri/widgets/Search",
"esri/widgets/BasemapGallery",
"esri/widgets/LayerList",
"esri/widgets/Expand",
"esri/renderers/SimpleRenderer",
"esri/geometry/Extent",
"esri/geometry/SpatialReference",
"esri/tasks/support/Query",
"esri/tasks/QueryTask",
"esri/Graphic",
"esri/widgets/Fullscreen"
function(
Map,
MapView,
CoordinateConversion,
GroupLayer,
FeatureLayer,
MapImageLayer,
Home,
Search,
BasemapGallery,
LayerList,
Expand,
SimpleRenderer,
Extent,
SpatialReference,
Query,
QueryTask,
Graphic,
Fullscreen
//map extent: Need this since no basemap; otherwise extent is pretty wonky
var bounds = new Extent({
"xmin":-103.5,
"ymin":33.0,
"xmax":-93.5,
"ymax":37.5,
"spatialReference":{"wkid":4326} //this is for the extent only; need to set map spatial reference in view.
// Oklahoma Counties Layer
var okcounties = new FeatureLayer({
url: "https://obsgis.csa.ou.edu:6443/arcgis/rest/services/ONHI/ArcGISServer_Counties/FeatureServer",
title: "Oklahoma Counties",
var trtemplate = {
// autocasts as new PopupTemplate()
title: "<strong>{label2} Centroid</strong>:",
content: "DD Centroid: {label2}<br> Level II Ecoregion: {label2}<br> Level I Ecoregion: {label2}"
// Township/Range
var townships = new FeatureLayer({
url: "https://obsgis.csa.ou.edu:6443/arcgis/rest/services/ONHI/PLSS/MapServer/0/",
outFields: ["*"],
title: "Township/Range"
//popupTemplate: template
// Sections
var sections = new FeatureLayer({
url: "https://obsgis.csa.ou.edu:6443/arcgis/rest/services/ONHI/PLSS/MapServer/1/",
outFields: ["*"],
title: "Section"
// Create GroupLayer for PLSS data
var PLSS = new GroupLayer({
title: "PLSS Data",
visible: false,
visibilityMode: "independent",
layers: [townships, sections]
var map = new Map({
//basemap: "satellite",
layers: [PLSS, okcounties]
var view = new MapView({
container: "viewDiv",
map: map,
//center: [-98.762150, 35.287798],
//zoom: 8,
extent: bounds,
spatialReference: 3857 //spatial reference of map; different from the extent
//Home button
var homeBtn = new Home({
view: view
// Add the home button to the top left corner of the view
view.ui.add(homeBtn, "top-left");
// create a search widget
var searchWidget = new Search({
view: view,
sources: [{
layer: new FeatureLayer({ //Notice the property is called layer Not featureLayer new to 4.11
popupTemplate: trtemplate,
//{ // autocasts as new PopupTemplate()
//title: "{label2}",
// overwriteActions: true
searchFields: ["label2"],
displayField: "label2",
exactMatch: false,
outFields: ["label2"],
placeholder: "example: 12N 10W IM",
popupTemplate: { // autocasts as new PopupTemplate()
title: "{str_label2}",
searchFields: ["str_label2"],
displayField: "str_label2",
exactMatch: false,
outFields: ["str_label2"],
name: "Section Township/Range",
placeholder: "example: Sec. 15 12N 10W IM",
url: "https://obsgis.csa.ou.edu:6443/arcgis/rest/services/ONHI/ArcGISServer_Counties/FeatureServer/0",
title: "{name} County",
searchFields: ["name"],
displayField: "name",
exactMatch: false,
outFields: ["name"],
placeholder: "example: Adair",
// Add the search widget to the top right corner of the view
view.ui.add(searchWidget, {
position: "top-right"
// Create a BasemapGallery widget instance and set
// its container to a div element
var basemapGallery = new BasemapGallery({
view: view,
container: document.createElement("div")
// Create an Expand instance for basemap gallery
var bgExpand = new Expand({
view: view,
expandTooltip: "Select basemap",
content: basemapGallery
// Add the expand instance to the ui
view.ui.add(bgExpand, "top-left");
// Add a legend instance to the panel of a
// ListItem in a LayerList instance
const layerList = new LayerList({
view: view,
listItemCreatedFunction: function(event) {
const item = event.item;
if (item.layer.type != "group")
{ // don't show legend twice
item.panel = {
content: "legend",
open: false
// Create an Expand instance for legend gallery
var lgExpand = new Expand({
view: view,
expandTooltip: "Expand Layer List",
content: layerList
view.ui.add(lgExpand, "top-left");
fullscreen = new Fullscreen({
view: view
view.ui.add(fullscreen, "top-right");
//Coordinate Conversion Widget
const ccWidget = new CoordinateConversion({
view: view
view.ui.add(ccWidget, "bottom-left");
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
