Hi all - I'm looking to create a point (will be svg) on a map with a label on it. I attached a photo of the intended result. However, I'm using a graphics layer to render the current symbol. If graphics layers do not support label making, how would you go about creating a marker point and label on the same layer?
Also, is it possible to layer text on top of markers? such as the number 1 on the maker in the screenshot.
