CDN broken - esri 4.14 javascript API
1958
7
11-17-2020 06:03 AM
NicholasRomano1
Hi. We have an app that relies on the esri 4.14 CDN to load the API. This cdn is not working this morning and is causing failure in our app.
Proof:
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=intro-mapview
change script url tag to 4.14
BlakeTerhune
MVP Frequent Contributor
It seems to be working for me. Maybe you just stumbled into a momentary outage?
NicholasRomano1
Did you change the script tag to 4.14 and refresh in the right corner? Certainly not working across multiple networks here...
BlakeTerhune
Yes, working with v4.14. No errors in console. I'm in Arizona, USA.
NicholasRomano1
Thanks, I'm in the Northeast US. could be a geographical outage I guess...
AndyGup
Thanks for reporting, sorry you are having issues. Tech Support is investigating and I'll pass on your additional information.
NicholasRomano1
Hi Andy.
Any idea when this might get fixed? This app is in production and has high visibility. Wondering if I need to hotfix to the latest API version.
Edit- Its fixed!
AndyGup
Awesome, glad it's working again for you. We are also working on a fix and doing additional testing.
