I want to add a bunch of widgets to a custom web app. Obviously, if there are a bunch of widgets in a single app, you run into issues of covering up too much of the map. Expand widget to the rescue.
The issue I'm running into is that I want to deliver a UI similar to what the Scene Viewer has going on with its expand widget, where every expand widget has been added to the same div.
I went through the samples and found that creating a new Expand Widget for each widget I want to add results in them being added separately with margin between each widget. The following code:
<!DOCTYPE HTML>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Expand widget - 4.8</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.8/esri/css/main.css">
<script src="https://js.arcgis.com/4.8/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script>
require([
"esri/Map",
"esri/views/SceneView",
"esri/widgets/Expand",
"esri/widgets/Search",
"esri/widgets/BasemapGallery",
"dojo/domReady!"
], function(
Map, SceneView, Expand, Search, BasemapGallery
var map = new Map({
basemap: "topo"
var view = new SceneView({
container: "viewDiv",
map: map
var searchWidget = new Search({
view: view,
container: document.createElement("div")
var basemapGallery = new BasemapGallery({
view: view
var searchExpand = new Expand({
view: view,
content: searchWidget
var bgExpand = new Expand({
view: view,
content: basemapGallery
view.ui.add([searchExpand, bgExpand], "top-right");
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
results in the following view.
I'm thinking I need to override the CSS and I found some sections in the API docs on doing that, but its a little heavy for a JS rookie like myself. How do I get the search and basemapGallery widgets into the same div similar to the first screenshot?
