Adding Custom Basemap in Basemap Gallery Widget
3367
06-18-2018 02:58 AM
Den-GIS
I'm trying to add custom basemap from organisation ArcGIS Server in the ESRI Basemap Gallery Widget. I cannot get it to work  although my custom basemap has a same spatial reference (wkid:100102 (3857)) as ESRI Basemaps.
Has anybody Idea what I'm doing wrong?
Thanks
    <!DOCTYPE html>
    <html>
    <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
      <!--The viewport meta tag is used to improve the presentation and behavior of the samples
        on iOS devices-->
      <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
      <title></title>
      <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.24/dijit/themes/claro/claro.css">
      <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.24/esri/css/esri.css">
      <style>
        html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
        #map{
          padding:0;
      </style>
      <script src="//js.arcgis.com/3.24/"></script>
      <script>
        var map;
        require([
          "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
          "dojo/parser",
          "esri/dijit/BasemapLayer", "esri/dijit/Basemap",
          "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
          "dojo/domReady!"
        ], function(
          Map, BasemapGallery, arcgisUtils,
          parser, BasemapLayer, Basemap
          parser.parse();
          map = new Map("map");
         var basemaps = [];
          var customBasemapLayer = new BasemapLayer({
            url: "https://organisationServer/arcgis/rest/services/folder/MapServer"
          var customBasemap = new Basemap({
            layers: [customBasemapLayer],
            title: "custom Basemap",
            thumbnailUrl: "images/basemap.png"
          basemaps.push(customBasemap);
          var worldImageryLayer = new BasemapLayer({
            url: "http://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer"
          var satelliteBasemap = new Basemap({
            layers: [worldImageryLayer],
            title: "Satellite",
            thumbnailUrl: "images/satellite.png"
          basemaps.push(satelliteBasemap);
          var basemapGallery = new BasemapGallery({
            showArcGISBasemaps: true,
            basemaps: basemaps,
            map: map
          }, "basemapGallery");
          basemapGallery.startup();
          basemapGallery.on("error", function(msg) {
            console.log("basemap gallery error:  ", msg);
      </script>
    </head>
    <body class="claro">
      <div data-dojo-type="dijit/layout/BorderContainer"
           data-dojo-props="design:'headline', gutters:false"
           style="width:100%;height:100%;margin:0;">
        <div id="map"
             data-dojo-type="dijit/layout/ContentPane"
             data-dojo-props="region:'center'"
             style="padding:0;">
          <div style="position:absolute; right:20px; top:10px; z-Index:999;">
            <div data-dojo-type="dijit/TitlePane"
                 data-dojo-props="title:'Switch Basemap', closable:false, open:false">
              <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
                <div id="basemapGallery"></div>
              </div>
            </div>
          </div>
        </div>
      </div>
    </body>
    </html>
RobertScheitlin__GISP
Great.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Denis,
   Your Layer has to have the same WKID and tiling Scheme. So if your WKID is the same then your tiling scheme must not match.
Den-GIS
Robert,
Thanks for the hint. I got it to work now.
Denis
Great.
