ArcGIS Maps for PowerBI - Postcode locations not recognised correctly
398
08-03-2023 04:59 AM
ChristianMercer
I'm attempting to create a visual for a Power BI Dashboard using the ArcGIS Maps for Power BI - this will aim to show the number of attendances based on postcodes. I am running into an issue however, whereby the visual seems to recognise a number of UK based postcodes as being in different countries, or just plots them in the middle of the Atlantic Ocean for some reason. Is this a known bug, or are there any solutions for this?
For additional context, the postcodes used are limited to the Postcode sector - the first part of the postcode (known as the outcode) and then the first value of the second part of the postcode (known as the incode). Please see an example attached which illustrates the issue that I'm experiencing.
Any help with this would be greatly appreciated!
Tags (3)
ChristianMercer
Please disregard this post (I forgot to add the screenshot) - please see https://community.esri.com/t5/arcgis-for-power-bi-questions/arcgis-maps-for-powerbi-postcode-locatio... instead.
ChristianMercer
