Current Status: Resolved as of 6/25/2021
Error I receive: Your ArcGIS account requires an add on license and associated privileges to use ArcGIS for power bi.
Problem: I am trying to log into the ArcGIS power BI add-on with an enterprise account. Reading from the documentation, there is no add-on that needs to be added because the Power BI feature should be automatically included. Has anyone had any luck getting this to work or experienced the same problem? I have a creator license so that should not be the problem.
Update 5/5/2021: Our Administrator has been in communications with our Representative about this licensing problem. Apparently ESRI is "behind" in providing these licenses to customers with an Enterprise environment. We still don't have an ETA for when the licenses will be available for the administrator to disperse to each user. So as far as ESRI's documentation on the Power BI license availability , will technically yes ESRI has them ,but when you will actually have access to them is completely different.
Update 6/25/2021: Our Administrator said that the Power BI add-on license has been added to the MyESRI Org Portal last Wednesday and he recently added the license to my account. I was finally able to log into PowerBI and the the Enterprise options of the ESRI Map feature. After communicating with our regional manager they were able to provide us these "Free" licenses after 2.5 months.
Note: The Power BI server is on premise, and our enterprise can be accessed online. We have Enterprise version 10.8.1 and are using IWA authentication.
ArcGIS / Power BI documentation: https://doc.arcgis.com/en/power-bi/get-started/arcgis-requirements.htm
