Survey123 to Dashboard
335
06-14-2023 04:16 AM
KatieSjolander
I have a Survey123 that was created and I am now trying to turn the results into a Dashboard. I am running into a problem of trying to get the answers from the same question to count as a value and be represented in a pie chart or gauge. Example of my Survey123:
Demographics on Subject:
1. Race? (Drop down to select from): White
2. Was there another Subject involved?
Yes/No (If YES is selected then another question comes up related to demographics of the person same as in question 1.
3. Race? (Drop down to select from): White
How do I get Dashboard to take both answers of "White" to count as 2 responses and be visually represented on a gauge or pie chart?
Thanks for any help!
JenniferAcunto
This is a great example of having to design your survey around your final product. I would add several hidden integrer questions in your survey, one question for each Race option. Each of these will have a calculation that will populate it based on the answers to the Race and 2nd Race questions in your survey.
if(${race}='White' and ${race2}='White', '2', if(${race}='White' and ${race2}!='White', '1', if(${race}!='White' and ${race2}='White', '1', '0')))
Then in your dashboard, you would create your pie chart (or serial chart) using the Categories from Fields option. Select each of your hidden Race integers you just created.
For more tips and tricks for designing surveys around dashboards, check out Dashboards That Pop: Survey123
- Jen
