AttributeInspector requires a FeatureLayer when using graphics?
3586
08-27-2012 07:12 AM
DuncanNisbett
I'm attempting to create a feature where a user is able to come in and create graphics to mark out excavation areas. The existing layers are all Dynamic layers. Through my research with the AttributeInspector (AI) it looks like it requires a FeatureLayer, which is a child of the Graphics layer. Is there a way to use the AttributeInspector without having to add a FeatureLayer? And if a FeatureLayer is required, can one create an "empty" layer just to satisfy the constraints of the AI?
I've attached a sample file of how I'm currently attempting to achieve this and obviously it doesn't work at the moment. Any insight someone might have would be greatly appreciated. I've also included the code in the post for easy reference.
[HTML]<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" />
    <meta name="viewport" content="width=device-width,user-scalable=no"/>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Maps Toolbar</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css">
    <style type="text/css">
      html, body {
        height: 100%; width: 100%; margin: 0; padding: 0;
    </style>
    <script type="text/javascript">
      dojoConfig = {
        parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0"></script>
      dojo.require("esri.map");
      dojo.require("esri.toolbars.draw");
      dojo.require("dijit.dijit"); // optimize: load dijit layer
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
   dojo.require("esri.toolbars.edit");
   dojo.require("dijit.form.Button");
      dojo.require("dijit.Menu");
   dojo.require("esri.layers.FeatureLayer");
dojo.require("esri.dijit.editing.TemplatePicker");
dojo.require("esri.dijit.AttributeInspector-all");
      var map, toolbar, editToolbar, symbol, geomTask;
   var ctxMenuForGraphics, ctxMenuForMap;
      function init() {
        var startExtent = new esri.geometry.Extent({"xmin":-11721159,"ymin":-1138850,"xmax":8277212,"ymax":9858297,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map",{extent:startExtent});
        dojo.connect(map, "onLoad", createToolbar);
        //add the world street map basemap
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
        map.addLayer(basemap);
      function createToolbar(themap) {
        //resize the map when the browser resizes
        dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
       toolbar = new esri.toolbars.Draw(map);
    editToolbar = new esri.toolbars.Edit(map);
       dojo.connect(toolbar, "onDrawEnd", addToMap);
      function addToMap(geometry) {
        toolbar.deactivate();
        map.showZoomSlider();
         switch (geometry.type) {
            case "polygon":
              var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25]));
              break;
          var graphic = new esri.Graphic(geometry, symbol);
    graphic.setAttributes({"Title": "My Shape", "Description": "My Test Description", "Perimeter": "0", "Area": "0"})
    graphic.setInfoTemplate(infoTemplateNew(graphic));
          map.graphics.add(graphic);
function infoTemplateNew(graphic){
  var infoWindow = new esri.InfoTemplate();
  infoWindow.setTitle(graphic.attributes.Title)
  //possible code to abstractly handle updating fields - errors out at the moment
  var layer = map.getLayer("map_graphics");
  //var layer = esri.layers.FeatureLayer;
  var layerInfos = [{'featureLayer': layer,'isEditable': false}];
  var attInspector = new esri.dijit.AttributeInspector({layerInfos: layerInfos}, dojo.create("div"));
  infoWindow.setContent(attInspector.domNode);
  return infoWindow;
function activateToolbar(graphic){
  var tool = 0;
  tool = tool | esri.toolbars.Edit.MOVE;
  tool = tool | esri.toolbars.Edit.EDIT_VERTICES;
  tool = tool | esri.toolbars.Edit.SCALE;
  tool = tool | esri.toolbars.Edit.ROTATE;
  var options = {
    allowAddVertices: true,
    allowDeleteVertices: true
  editToolbar.activate(tool, graphic, options);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
<div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
    <div id="header" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" style="height:75px;text-align:left;font-weight:bold;font-size:14px;color:#400D12;overflow:hidden;">
      <span>Draw:<br /></span>
      <button data-dojo-type="dijit.form.Button" data-dojo-props="onClick:function(){toolbar.activate(esri.toolbars.Draw.POLYGON);map.hideZoomSlider();}">Polygon</button>
      <!--The Arrow,Triangle,Circle and Ellipse types all draw with the polygon symbol-->
    </div>
    <div id="map" data-dojo-type="dijit.layout.ContentPane" style="border:solid 2px #587498;margin:5px;" data-dojo-props="region:'center'">
    </div>
</div>
  </body>
</html>
[/HTML]
DuncanNisbett
Came up with a workaround to my issue. Instead of attempting to modify attributes of the Graphic with the AttributeInspector, I created my own form that allowed me to specifically designate the attributes to modify and then save/update accordingly. I would still be interested in finding a way through this problem, but it is no longer a stumbling block in my development.
KellyHutchins
Esri Notable Contributor
You could create a feature collection based feature layer and use that with the AttributeInspector widget. Here's an example:
<html lang="en">
  <head>
      on iOS devices-->
    <title>Validate Attributes</title>
    <!-- include dojo theme -->
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/claro/claro.css">
      .dj_ie .infowindow .window .top .right .user .content { position: relative; }
      .dj_ie .simpleInfoWindow .content {position: relative;}
    </style>
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; overflow:hidden; }
      #leftPane{
        overflow:hidden;
        border:none;
        color:#5C832F;
      #map{
        border: solid medium #382513;
        padding:0;
      .esriAttributeInspector{
          atiLayerName:'Building Details'
      .templatePicker{
        border:none !important;
      .templatePicker .grid .groupLabel{
        display:none;
    </style>
    <!-- specify dojo configuration to parse dijits at load time -->
      dojoConfig = {
        parseOnLoad:true
    </script>
    <!-- reference ArcGIS JavaScript API -->
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script>
      //require selection dijit
      dojo.require("esri.dijit.editing.Editor-all");
      dojo.require("dijit.form.ValidationTextBox");
      var map;
      function init() {
        var initialExtent = new esri.geometry.Extent({"xmin":-13062820,"ymin":4063755,"xmax":-13048794,"ymax":4071609,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map", { extent:initialExtent, slider: false, nav: true });
        dojo.connect(map, "onLoad", function() {
        dojo.connect(map, "onLayersAddResult", initEditor);
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        var featureCollection = {};
        featureCollection.layerDefinition = {"id":0,"name":"Notes","type":"Feature Layer","displayField":"name","description":"","copyrightText":"","relationships":[],"geometryType":"esriGeometryPoint","minScale":0,"maxScale":0,"extent":{"xmin":-165.874652126,"ymin":-49.9999999999999,"xmax":176.176078869,"ymax":76.745946916,"spatialReference":{"wkid":4326}},"drawingInfo":{"renderer":{"type":"simple","symbol":{"type":"esriPMS","url":"images/flickr.png","contentType":"image/png","color":null,"width":28,"height":28,"angle":0,"xoffset":0,"yoffset":0},"label":"","description":""},"transparency":0,"labelingInfo":null},"hasAttachments":true,"htmlPopupType":"esriServerHTMLPopupTypeAsHTMLText","objectIdField":"objectid","globalIdField":"globalid","typeIdField":"","fields":[{"name":"objectid","type":"esriFieldTypeOID","alias":"Objectid","editable":false,"domain":null},{"name":"note","type":"esriFieldTypeString","alias":"Note","editable":true,"length":255,"domain":null},{"name":"link","type":"esriFieldTypeString","alias":"Link","editable":true,"length":2048,"domain":null},{"name":"name","type":"esriFieldTypeString","alias":"Name","editable":true,"length":50,"domain":null},{"name":"email","type":"esriFieldTypeString","alias":"Email","editable":true,"length":50,"domain":null},{"name":"phone","type":"esriFieldTypeString","alias":"Phone","editable":true,"length":50,"domain":null},{"name":"globalid","type":"esriFieldTypeGlobalID","alias":"globalid","editable":false,"length":38,"domain":null},{"name":"notedate","type":"esriFieldTypeDate","alias":"Notedate","editable":false,"length":36,"domain":null}],"types":[],"templates":[{"name":"Notes","description":"","drawingTool":"esriFeatureEditToolPoint","prototype":{"attributes":{"notedate":null,"note":null,"link":null,"name":null,"email":null,"phone":null}}}],"capabilities":"Query,Editing"}
         var fields = dojo.map(featureCollection.layerDefinition.fields, function(field) {
          return field.name;
        var featureLayer = new esri.layers.FeatureLayer(featureCollection, {
          outFields: fields
        map.addLayers([featureLayer]);
      function initEditor(results) {
        //only one layer
        var featureLayer = results[0].layer;
        var templatePicker = new esri.dijit.editing.TemplatePicker({
          featureLayers: [featureLayer],
          rows: 'auto',
          groupingEnabled:false,
          columns: 1
        },'editorDiv');
        templatePicker.startup();
       var layerInfos = [{
          'featureLayer':featureLayer,
          'showAttachments':false,
          'showDeleteButton':false,
          'fieldInfos':[
            {'fieldName':'name','label':'Name'},
            {'fieldName':'email','label':'Email'},
            {'fieldName':'phone','label':'Phone'},
            {'fieldName':'note','label':'Details', 'stringFieldOption':esri.dijit.AttributeInspector.STRING_FIELD_OPTION_TEXTAREA},
            {'fieldName':'notedate','label':'Date'}
        //define the editor settings
        var settings = {
          map: map,
          templatePicker:templatePicker,
          layerInfos:layerInfos
        var params = {settings: settings};
        //Create the editor widget
        var editorWidget = new esri.dijit.editing.Editor(params);
        editorWidget.startup();
        //resize the info window (attribute inspector)
        map.infoWindow.resize(295,245);
    </script>
  </head>
    <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'sidebar'" style="width:100%;height:100%;">
      <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div>
      <div id="leftPane" data-dojo-type="dijit.layout.ContentPane" style="width:100px;"  data-dojo-props="region:'left'">
        <div id="editorDiv"></div>
        <div></div>
      </div>
    </div>
  </body>
</html>
DerivenC
<html lang="en">
  <head>
      on iOS devices-->
    </style>
    <style>
      #leftPane{
        overflow:hidden;
        border:none;
        color:#5C832F;
      #map{
        padding:0;
      .templatePicker{
        display:none;
    </style>
      dojoConfig = {
        parseOnLoad:true
    </script>
      var map;
      function init() {
          return field.name;
          outFields: fields
        //only one layer
          rows: 'auto',
          columns: 1
        },'editorDiv');
       var layerInfos = [{
          'fieldInfos':[
        var settings = {
          map: map,
    </script>
  </head>
        <div></div>
      </div>
    </div>
  </body>
</html>
^ This is awesome!  Thank you!
