Python - Negative value with field Calculator
10822
13
07-24-2012 05:47 AM
Pierre-LucBoivin
I'm trying to subtract two integer columns and put the result into a text field. I got good result with positive valuesâ??â??, but I have a problem with negative valuesâ??â??.
[ATTACH=CONFIG]16352[/ATTACH]
Variation column is the result I get with this formula :
def Resultat(x,y):
 diff =  x-y
 return '%d:%02d' % divmod(diff, 60)
Variation = Resultat( !ScePUPbr! , !SitPUPbr!)
Testvari column is the result if I reverse the values â??â??xy
Testvari2 column is the result I should get
Thanks you for help
Pierre-Luc
Pierre-LucBoivin
Here the final solution !
def Resultat(x,y):
 diff =  x-y
 if diff < 0:
  sign = '-'
 else:
  sign = ''
 return sign+'%d:%02d' % divmod(abs(diff), 60)
Thanks everyone for your help
SolomonPulapkura
What expression are you using to calculate Testvari2?
The expression you provided is for Variation.
Pierre-LucBoivin
I populate the field manually using the field calculator !!
BruceNielsen
Take the absolute value of the difference:
diff = abs(x-y)
Pierre-LucBoivin
diff = abs(x-y)
I've tried this solution but it's isn't returning the minus before my number !
BruceNielsen
This should add the negative sign, if needed:
def Resultat(x,y):
    diff =  x-y
    if diff < 0:
        sign = '-'
    else:
        sign = '' #These are two single quotes (an empty string)
    return '%s%d:%02d' % (sign, divmod(diff, 60))
Pierre-LucBoivin
Thanks a lot Bruce for helping !
I think we are almost there but i'm still having an error !!
ERROR 000539: Error running expression: Resultat( -2000 , 0) <type 'exceptions.TypeError'>: %d format: a number is required, not tuple
I tried to fix the error but it wasn't successful .
BruceNielsen
We'll try it without using string formatting for the sign then:
def Resultat(x,y):
    diff =  x-y
    if diff < 0:
        sign = '-'
    else:
    return sign + '%d:%02d' % divmod(diff, 60)
Pierre-LucBoivin
I thought this code will work too but it returning the same value as the Variation column but I have two minus before the number ex:(--1:56)
I'm try to put the abs() but it was evident it wouldn't work.
def Resultat(x,y):
    diff =  abs(x-y) #abs doesn't make any difference without a positive and negative value
    if diff < 0:
        sign = '-'
    else:
is it because of the %02d that it always calculate the difference from 2:00 ?
BruceNielsen
If you go back to your original formula, but set diff = y - x, does that give you the results you expect?
