error in SelectLayerByAttribute
2465
7
05-05-2012 03:00 PM
ElaineKuo
Hello
System: ArcGIS 9.3
pythonWin: 2.5
Problem 1:
Using SelectLayerByAttribute but error showed:
ExecuteError: ERROR 000358: Invalid expression
Please kindly help indicate the mistake in the query code.
Also, a shape file is attached for trial.
Thanks a lot.
 ##Script Name: Delete rows ##Description: delete selected rows ##Created By: Elaine Kuo ##Date: 04/05/2012  #Import standard library modules import arcgisscripting import os  #Create the Geoprocessor object gp = arcgisscripting.create(9.3)  #Set the input workspace #GP.workspace = sys.argv[1] #Set the workspace. gp.Workspace= "G:/temp"  #Set the output workspace #outWorkspace = sys.argv[2] #Set the workspace. List all of the feature classes in the dataset outWorkspace= "G:/temp/test"  #Get a list of the featureclasses in the input folder fcs = gp.ListFeatureClasses()  # Loop through every item in the list that was just generated for fc in fcs:      # Break out the name, no path or extension, using the describe object.     desc = gp.describe(fc)     featureName = desc.name      # Make featureclasses as layers     gp.OverWriteOutput = 1     gp.toolbox = "Data Management"     gp.MakeFeatureLayer("geor0313_p.shp","geor0313_p_lyr")          #Get a list of the fields in the featureclass     fields = gp.ListFields("geor0313_p_lyr", "C*", "String")      # Loop through every item in the list that was just generated      for field in fields:          gp.toolbox = "Data Management"               # Select records to be deleted (C*, i.e. C7658)         query = "\"C*\" = 'R'"         gp.SelectLayerByAttribute("geor0313_p_lyr", "ADD_TO_SELECTION", query)          # Delete selected records         gp.deleterows("geor0313_p_lyr")              #Validate the new feature class name for the output workspace.     outFeatureClass = outWorkspace + os.sep +GP.ValidateTableName("geor0313_p_lyr",outWorkspace)
FabianBlau
In arcgisscripting 9.3 ListFeatureClasses() returns not a string but an object.
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=ListFields_method.
This object is like a container for severals varaibles and functions (for a  detailed explanation of objects read some smart books;) http://en.wikipedia.org/wiki/Object_%28computer_science%29)
One of the attributes is the fieldname -> http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=Field_properties.
Use AddMessage when you start a script from a toolbox.
Use print starting a script in python.
print type(field)
BruceNielsen
The where clause in selectlayerbyattribute does not recognize wildcard characters. You need to use the field variable that you're creating in the inner loop instead. Try this:
query = "\"%s\" = 'R'" % field
This will insert the field variable into the query expression each time the loop executes.
ElaineKuo
system arcGIS 9.3
Thanks for the response.
However, the same error still occurred after modifying the code as below.
Please kindly help and thanks.
##Date: 04/05/2012
import os
#Set the workspace.
for fc in fcs:
FabianBlau
I guess field is a Field Object, not a String. Check this with gp.addMessage(type(field)).
So try:
query = "\"%s\" = 'R'" % field.Name
ElaineKuo
Thanks a lot.
You are right.
Please kindly explain why it works with "query = "\"%s\" = 'R'" % field.Name" instead of "query = "\"%s\" = 'R'" % field"
Also, please kindly help how to run gp.addMessage(type(field)) using PythonWin for a beginner. 🙂
FabianBlau
print type(field)
ElaineKuo
Thanks a lot.
How to mark that you helped answer my questions 😮
FabianBlau
There is a button on the right side (sign in first) :D.
