Exception after stand alone application was closed
1238
10
03-18-2012 08:13 AM
MarkMindlin
We've created simple stand alone windows application, that have only one code string:
Geoprocessor pGeoP = new Geoprocessor();
After application was closed we get exception message (see the attachment)
All answer will be appreciated.
AlexanderGray
Honored Contributor
Have you tried releasing the object explicitly either with ComReleaser or MarshalComRelease?
MarkMindlin
ComReleaser did not help.
Do you mean Marshal.ReleaseComObject(pGeoP)?
If so, this gets exception "The object's type must be  __ComObject ..."
I should stress that we use ArcInfo 10 SP2. But in 9.3.1 it was working.
MarkMindlin
One more thing - we use .Net Framework 3.5.
AlexanderGray
Honored Contributor
Sorry, I got confused with GeoprocessorClass which is a com class, Geoprocessor is a .net class.  The first is part of ESRI.ArcGIS.Geoprocessing, the latter is part of ESRI.ArcGIS.Geoprocessor.  Running SP3 with framework 3.5,  I didn't get an error just creating an instance of the class and letting it go out of scope...  I haven't used the Geoprocessor class since 9.2.  Could be a bug at 10 SP2.  I always use the GeoprocessorClass, the example seem written for this class (I believe it was new to 9.3.)
GeorgeFaraj
Are you doing license initialization? I have that line of code in an ArcEngine program running under version 10, service pack 3 without incident but I have an actual ArcEngine program that binds the license and ensures the runtime is available.
MarkMindlin
Yes, there is no doubt, that we use standart wizard to add License checking to the VS project.
In addition (as a support recommends) we added - RuntimeManager.Bind(product code); - as a first line in method Main(). In this case - we do our best. (?)
AlexanderGray
Honored Contributor
Lack of binding or license checkout would give you a different error.  Do you have old versions of python hanging around?  I had some problems with that and using the geoprocessing tools in the desktop interface.
GeorgeFaraj
Well, that is clearly more than one code string. Have you tried the application on a machine with a clean install?  Have you tried moving to service pack 3?
MarkMindlin
What do you mean "clean install"? How can I do "clean install" on the users' desktop? It is not about 1-2 users 🙂
No, SP3 will be for our office only by summer.
