Hi all, I have a simple script that adds some fields, prompts the user for the info to fill those fields, and populates them via fieldcalculator. However, if I try to use any user input (i.e. getParameterAsText) at or above the 6th parameter (i.e. getParameterAsText(5)) it fails. I get the following error: (see attached screenshot). Here is the script: # Import system modules
import arcpy, sys
from arcpy import env
# Set local variables
inFeatures = arcpy.GetParameterAsText(0)
name = arcpy.GetParameterAsText(1)
fieldName = name + 'IDPK'
fieldAlias = fieldName
arcpy.AddField_management(inFeatures, fieldName, "TEXT", "", "", 20, fieldAlias)
expression = "autoIncrement(arcpy.GetParameterAsText(2), arcpy.GetParameterAsText(3), !INSTLN_ID!)"
codeblock = """rec = 0
def autoIncrement(siteID, instalID, instlnID):
global rec
length = len(instlnID)
if (length == 4):
pStart = 1
pInterval = 1
if (rec == 0):
rec = pStart
else:
rec = rec + pInterval
zeros = 15 - len(instalID) - len(siteID)
return siteID + '_' + instalID + '0001' + str(rec).zfill(zeros)"""
# Execute CalculateField
arcpy.CalculateField_management(inFeatures, fieldName, expression, "PYTHON", codeblock)
realPropertySiteUniqueID = arcpy.GetParameterAsText(4)
arcpy.AddField_management(inFeatures, "realPropertySiteUniqueID", "LONG")
arcpy.CalculateField_management(inFeatures, "realPropertySiteUniqueID", realPropertySiteUniqueID)
realPropertyUniqueID = arcpy.GetParameterAsText(5)
arcpy.AddField_management(inFeatures, "realPropertyUniqueID", "TEXT", "", "", 3, "realPropertyUniqueID")
arcpy.CalculateField_management(inFeatures, "realPropertyUniqueID", realPropertyUniqueID)
wacInnrCode = arcpy.GetParameterAsText(6)
arcpy.AddField_management(inFeatures, "wacInnrCode", "TEXT", "", "", 10, "wacInnrCode")
arcpy.CalculateField_management(inFeatures, "wacInnrCode", wacInnrCode)
owner = arcpy.GetParameterAsText(7)
arcpy.AddField_management(inFeatures, "owner", "TEXT", "", "", 4, "owner")
arcpy.CalculateField_management(inFeatures, "owner", owner)
Thank you for your time. Arc 10 SP3Windows 7
