how to run exportwebmap service?
3486
08-31-2011 11:09 PM
zhuzheng
i want to do one demo about exportwebmap service. but i always get the error. the attchment is  the error infomation.
the webmap as josn is blow:
"mapOptions" : {
"extent" : {
"xmin":2473180.90049606,
"ymin":679774.629817489,
"xmax":2500969.21844998,
"ymax":708732.161710566,
"spatialReference" : {
"wkid" : 2264
"scale" : 44898,
"wkid" : 2264
"operationalLayers" : [
"url" : "http://localhost:6080/arcgis/rest/services/Ex3/MapServer",
"title" : "Homeland security operations",
"opacity" : 0.8,
"visibleLayers" : [
0,
"showSublayerLegends" : [
"baseMap" : {
"title" : "My Basemap",
"baseMapLayers" :  [
"exportOptions": {
"dpi" : 100,
"outputSize" :  [
500,
500
i have tried servel times , but the result is the same. Does everyone meet this problem.
how do you use the exportwebmap service?
thank you very much.
SrinivasVinnakota
Zhu,
Using the JSON request that you posted and making a few changes to point to a service on my server I did not receive any errors. Could you try the below request and post the results?
    "mapOptions": {
        "extent": {
            "xmin": -14383517,
            "ymin": 1324871,
            "xmax": -7081003,
            "ymax": 8627386,
            "spatialReference": {
                "wkid": 102100
        "scale": 69000000,
            "wkid": 102100
    "operationalLayers": [ ],
    "baseMap": {
        "title": "My Basemap",
        "baseMapLayers": [
                "url": "http://servicesbeta.esri.com/ArcGIS/rest/services/Demographics/USA_1990-2000_Population_Change/MapServer"
    "exportOptions": {
        "dpi": 100,
        "outputSize": [
            500,
            500
zhuzheng
svinnakota, thanks for your response.
i copied your json code to the web_map_as_json,then run the excute operation.
the error is the same. you can see it in the attchment file.
thank you ver much.
My os is windows 7.
SrinivasVinnakota
zhu,
could you please contact Esri support and log an incident for them to look in to this issue? I am unable to reproduce the error that you are getting - java process crashes when running exportWebMap tool.
