Geodatabase Toolset 9.2 with ArcFM and custom com objects
1786
08-02-2011 05:28 AM
NiallCarter
Hi All
Working for a large utility company with ArcFM installed and using ArcFM objects, I am running into a problem using the 9.2 Geodatabase toolset. When trying to fetch drawing speeds I receive the error attached to this post.
I have added a shape file and non-ArcFM features and proven that the draw speed tool works as expected.
Is this a known issue, is there a way to find draw speeds of layers that are ArcFM objects?
Niall Carter
DerekLaw
Esri Esteemed Contributor
Hi Niall,
... Is this a known issue, is there a way to find draw speeds of layers that are ArcFM objects?
You're correct, the GDBT 9.2 release was not designed to work with custom ArcFM objects.
This is a known limitation of the developer sample.
Hope this helps,
NiallCarter
Thanks for the reply Derek
Do you know of a way, or a similar set of tools to measure layer/map draw speed in ArcGIS Desktop 9.2?
DerekLaw
Hi Niall,
Sorry, I'm not aware of any performance metric tools for measuring the rendering of custom ArcFM objects in ArcMap.
I suggest you try asking on the ArcFM/Telvent forums:
Telvent GIS Tech Support - Forums
Hope this helps,
