Difficulty with Query filter WhereClause using different fields
1187
07-22-2010 12:48 PM
deleted-user-h2MwrUDd3vgt
I'm trying to create a query filter in order to guarantee that a user doesn't use the same value twice but am having difficulty creating a WhereClause that evaluates two different fields. I'm able to get it to work using one field, but when I add the second clause I get the following compile error:
Type-declaration character does not match declared data type.
I would appreciate any ideas as to how to fix this error, or any suggestions as to how I could accomplish the same task a different way.
Thanks!
Public Sub DuplicateEntry()
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Set pMxDoc = ThisDocument
Set pMap = pMxDoc.FocusMap
Dim pFLayer As IFeatureLayer
Set pFLayer = pMap.Layer(0)
Dim pFClass As IFeatureClass
Set pFClass = pFLayer.FeatureClass
' query filter to test to see if the input value already exists
Dim pQf As IQueryFilter
Set pQf = New QueryFilter
pQf.WhereClause = "PHOTO_NO = " & frmRamp.txtPhoto.Text& And "WARD =" & frmRamp.txtWard.Text&
' if it exists show message
If pFClass.FeatureCount(pQf) > 0 Then
MsgBox "Value already exists, try again!", vbOKOnly, "Forum Help"
frmRamp.Hide
frmRamp.Show
Exit Sub
End If
End Sub
KenBuja
MVP Esteemed Contributor
You have your quotes in the wrong place. Try this for your whereclause:
pQf.WhereClause = "PHOTO_NO = " & frmRamp.txtPhoto.Text & " And WARD =" & frmRamp.txtWard.Text
That did it, thanks a ton! I think I tried every variation trying to get this thing to work.
