Selectable Layer(s) in Python - Not TOC buttons
2458
06-23-2014 08:38 AM
ChrisHanes1
I have a Python Addin that selects a feature by mouse click location and updates the attributes (to a per-determined value) or deletes it based on the button I click in the toolbar (I am flagging the layer on the fly).  This layer I am updating is simply a reference layer (a result of  QC script).  The layer the QC script was run on, will be edited to correct mistakes, so I really only want that as my selectable layer, so I can continue editing after flagging a QC polygon as resolved, ignored, etc.
The problem is that when I run my tool to update the polygon, it changes the list of selectable layers in my table of contents and adds the layer I updated through the tool.  I want to be able to set that back/set it to a particular layer after using my button.  Otherwise I have to keep setting it manually.
Anyone know how to set the selectable layers through a script and not by clicking buttons in the TOC?
It should be part of arcpy.mapping, but it is not:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00s300000008000000
KerryAlley
I don't know of a way to make a layer un-selectable through Python scripts, which I'm guessing is intentional because layers are always selectable from a script's perspective.  (For example, arcpy.SelectLayerByLocation_management works on a layer even if it is not selectable in ArcMap, and the layer remains un-selectable even after running arcpy.SelectLayerByLocation_management via script or toolbox.)
If you are updating a layer from a layer file, just make sure the layer file (layer.lyr) you are referencing was created from a layer that was not selectable, then it should preserve that property when brought into your map document.
Kerry
ChrisHarlow1
Would you be willing to share the code for this?  I'm trying to do a similar thing but take an attribute value from one selected feature and input it along with a string into an attribute field of another feature class.
KerryAlley
Here's the code for the Python add-in I was referring to.  Keep in mind that it is meant to work with our own data, so it would require significant changes to perform similarly with someone else's data.
#ShieldToolAddin.py
#By Kerry Alley 2013-03-12
#Vermont Agency of Transportation
#Python Add-In for ArcMap 10.1, 10.2
#SELECT_ROAD (button)
#When activated, will select features within 20 map-meters of the mouse click on the map.
#The features are selected only from the top-most layer with the GDB_HMS.HMSADMIN.rdsmall_arc
#  data source, regardless of layer name.
#CREATE_SHIELD (button)
#Requires that a single rdsmall_arc feature already be selected
#User makes a single click on the map to indicate the location of the highway shield, and
#  makes a double-click where the leader line extending from the highway shield will end.
#Both a point feature and a line feature are created, with relevant attributes transferred
#  from the selected rdsmall_arc feature.
#There is an un-commentable option in this script that sets the length of the leader line to
#  a fixed length, for uniformity.
#NOTE: This addin works "normally" if there is not an active editing session in ArcMap, but if
#  there is an active editing session, the addin "crashes" at the call to stopEditing().  The
#  features will still be created, but the screen will not refresh if there is a pre-existing
#  editing session active.
import arcpy, time, os, math
import pythonaddins
class SelectRoadClass(object):
    """Implementation for ShieldToolAddinA_addin.tool (Tool)"""
    def __init__(self):
        self.enabled = True
        self.shape = "NONE"
    def onMouseDownMap(self, x, y, button, shift):
 #start_time = time.time() #only used to compare run-times of different versions of the script
 rdsmall_dataSource = r"GDB_HMS.HMSADMIN.rdsmall_arc"
 mxd = arcpy.mapping.MapDocument('current')
 flag_rdsmall = 0 #flag_rdsmall is used to flag the first occurence of a layer having the desired dataSource in TOC
 for lyr in arcpy.mapping.ListLayers(mxd):
     if lyr.supports("dataSource"):
  if str(lyr.dataSource).endswith(rdsmall_dataSource) and not flag_rdsmall:
      rdsmall_lyr = lyr
      flag_rdsmall = 1
 point = arcpy.Point()
 point.X = x
 point.Y = y
 pointGeometry = arcpy.PointGeometry(point)
 arcpy.SelectLayerByLocation_management(rdsmall_lyr, "WITHIN_A_DISTANCE", pointGeometry, "20 Meters", "NEW_SELECTION")
 #print time.time() - start_time, "seconds"
class CreateShieldClass(object):
    """Implementation for ShieldToolAddinB_addin.tool (Tool)"""
    def __init__(self):
 self.enabled = True
 self.cursor = 3
 self.shape = "LINE"
    def onLine(self, line_geometry):
 #start_time = time.time() #only used to compare rough run-times of different versions of the script
 #Hard-wiring the exact feature classes that will be edited with shield tool.
 shield_points_dataSource = r"GDB_HMS.HMSADMIN.hms_shields_points"
 shield_arcs_dataSource = r"GDB_HMS.HMSADMIN.hms_shields_arcs"
 #for new shields to appear in current mxd, this script must refer to layers in the current mxd
 lyrs = arcpy.mapping.ListLayers(mxd)
 flag_points = 0
 flag_arcs = 0
 flag_rdsmall = 0
  if str(lyr.dataSource).endswith(shield_points_dataSource) and flag_points == 0:
      shield_points_lyr = lyr
      flag_points = 1
  if str(lyr.dataSource).endswith(shield_arcs_dataSource) and flag_arcs == 0:
      shield_arcs_lyr = lyr
      flag_arcs = 1
  if str(lyr.dataSource).endswith(rdsmall_dataSource) and flag_rdsmall == 0:
      rdsmall_lyr = lyr
      flag_rdsmall = 1
 if not (shield_points_lyr and shield_arcs_lyr and rdsmall_lyr):
     print "Must have 3 layers in this mxd: shield points, shield arcs, and rdsmall"
 #only allow shield creation if a single road arc is selected
 num_road_arcs = int(arcpy.GetCount_management(rdsmall_lyr).getOutput(0))
 print "%s rdsmall arc(s) selected" %num_road_arcs
 if num_road_arcs == 1:
     workspace = rdsmall_lyr.workspacePath  #(refers to .sde file in DatabaseConnections)
     arcpy.env.workspace = workspace
     edit = arcpy.da.Editor(workspace)
     edit.startEditing(True, True) #with undo, multiuser mode
     #identify maximum SHI_GRP_ID value currently used in shields feature class
     max_id = sorted(arcpy.da.SearchCursor(shield_points_lyr.dataSource, "SHI_GRP_ID"), reverse = 1)[0][0]
     #print max_id + 1
     #collect selected road arc attributes
     rdsmall_values = sorted(arcpy.da.SearchCursor(rdsmall_lyr, ["UA", "FAID_S", "CTCODE", "RTNUMBER", "AOTCLASS"]))
     #uncomment the last line of this block of code to turn off the truncation of the leader line
     #determine line coordinates, slope, and truncated line geometry based on first and last point.
     a_pt = line_geometry.firstPoint
     b_pt = line_geometry.lastPoint
     slope = (b_pt.Y - a_pt.Y)/(b_pt.X - a_pt.X)
     theta = math.atan(slope)
     #fixed_length = 150.
     fixed_length = 185.
     if b_pt.X - a_pt.X < 0:
  x = fixed_length * math.cos(theta) * -1
  y = fixed_length * math.sin(theta) * -1
     else:
     point.X = a_pt.X + x
     point.Y = a_pt.Y + y
     array = arcpy.Array()
     array.add(line_geometry.firstPoint)
     array.add(point)
     fixed_line = arcpy.Polyline(array)
     #To remove the constraint of fixed shield arc lengths, uncomment the following line:
     fixed_line = line_geometry #this line reverts the fixed_line to the original input geometry
     #create shield point feature and populate attributes
     new_points_Cur = arcpy.da.InsertCursor(shield_points_lyr, ["SHAPE@XY", "UA", "FAID_S", "CTCODE", "RTNUMBER", "AOTCLASS", "SHI_GRP_ID", "INSET", "ISVISIBLE", "SUBINSET"])
     test = (fixed_line.firstPoint,) + tuple(rdsmall_values) + (max_id + 1,)
     test_tuple = ((test[0].X, test[0].Y), test[1][0], test[1][1], str(test[1][2]), str(test[1][3]), test[1][4], test[2], "N", 1, "N")
     #test_tuple = ((test[0].X, test[0].Y), rdsmall_values[0], str(rdsmall_values[2]), str(rdsmall_values[3]), rdsmall_values[4], max_id + 1, "N", 1, "N")
     edit.startOperation()
     new_points_Cur.insertRow(test_tuple)
     edit.stopOperation()
     del new_points_Cur
     #create shield arc feature and populate SHI_GRP_ID, CTCODE, UA, INSET, ISVISIBLE, and SUBINSET fields
     new_arc_Cur = arcpy.da.InsertCursor(shield_arcs_lyr.dataSource, ["SHAPE@", "SHI_GRP_ID", "CTCODE", "UA", "INSET", "ISVISIBLE", "SUBINSET"])
     new_arc_Cur.insertRow([fixed_line, max_id + 1, str(rdsmall_values[0][2]), rdsmall_values[0][0], "N", 1, "N"])
     del new_arc_Cur
     edit.stopEditing(True) #save changes (doesn't work if an editing session is open in ArcMap, but )
     arcpy.SelectLayerByAttribute_management(rdsmall_lyr, "CLEAR_SELECTION")
     arcpy.RefreshActiveView()
 else:
     print "Shield Not Created"
     print "Must select a single arc from rdsmall"
ChrisHarlow1
Thanks!  I have my process built and it works in pieces, but when combined it fails.  I more just want to see how other people are doing a similar process so hopefully I'll be able to get mine to work.
