zoom not zooming to mouse location
3079
7
06-20-2014 12:30 PM
jaykapalczynski
Honored Contributor
I have this app...when I scroll zoom it does not zoom to where my mouse pointer is...its not bad in this jsfiddle but in my app its far worse...check the website below...and scroll / zoom in watch how it pushes to the right
Any thoughts?
Click the MAP button to bring up map
http://jsfiddle.net/Q6ss8/6/
https://fwisweb1.dgif.virginia.gov/dgifmapping/2PopupMapInputTextboxCoordinatesy.html
2 other questions:
1. Can I convert the XY to Lat Long after I click the map to populate the text boxes with XY?
2. Is there a better way to do this than using identifyParams?
KenBuja
MVP Esteemed Contributor
Adding these lines seems to fix the Fiddle
    function DragDrop() {         //alert("IN DragDrop");         domUtils.toggle(dom.byId("divSplashScreenContainer"));         app.map.resize();         app.map.reposition();     }
These should be called after the map DIV has been repositioned and resized.
jaykapalczynski
Honored Contributor
Map is still zooming to the right ????  Dont know why
Think I got my XY Coordinate corrected with this
var normalizedVal = webMercatorUtils.xyToLngLat(XCoord, YCoord);
alert(normalizedVal);
Although the translated Coordinates put me in the Atlantic Ocean
JS App is returning -8036423.598 4246950.54
Translated with webMercatorUtils i get -72.192421 and 35.6089
Should be around -77 and 37
Dont know if there is a better way to capture XY coordinates and populate input boxes
KenBuja
KenBuja
As for your other question, you can use getLatitude and getLongitude methods on a Point. See this thread
jaykapalczynski
Honored Contributor
Awesome....thank you all very much.....very very appreciated.
jaykapalczynski
Honored Contributor
Ken Buja
Is that getting the center of the map?  I am trying to get the XY of a map click
KenBuja
It's just an example of different ways to get the latitude and longitude from a point. That thread used the example of the map's center, but a point is a point.
KenBuja
If your question was answered, don't forget to click the check mark on the appropriate post. This helps others when searching for solutions to this question.
