Add Cogo Fields via arcpy
2009
5
06-16-2014 09:29 AM
NoahHuntington
Is anyone aware of a way to add cogo fields to a feature class using a stand alone script?
JakeSkinner
Esri Esteemed Contributor
Hi Noah,
There is not a arcpy function that will add the COGO fields, but you can easily create a script to do this using the Add Field tool.  The below link provides the field names, description, alias, and format for each of the fields:
http://resources.arcgis.com/en/help/main/10.2/index.html#//01m700000042000000
Ex:
arcpy.AddField_management(table, "Direction", "Text", "", "", "12", "COGO Direction")
NoahHuntington
Thanks Jake! I am probably missing something here.  How do I then populate this field with directions?
JakeSkinner
Does this have to be accomplished through python as well?  Not sure if this is possible, but you can do this using the COGO toolbar:
http://resources.arcgis.com/en/help/main/10.2/index.html#//01m700000008000000
NoahHuntington
Yes unfortunatley I need to accomplish this dynamically and as part of a much larger python script?
NoahHuntington
Yes unfortunately I need to accomplish this dynamically and as part of a much larger python script?
