layer names to text box using C#
3459
06-14-2014 11:47 PM
ababreddy
Hi, I am trying get layer names to text  box but i am not getting result.Here is my code
Can any one help
IMxDocument imx = m_application.Document as IMxDocument;
            IMap map = imx.FocusMap;
            StreamWriter sw = new StreamWriter("C:\\temp\\layer.txt");
            ILayer layer =null;
           // int lcount = map.LayerCount;
            IEnumLayer player = map.get_Layers(null, false);
            for (int i=0;i<map.LayerCount;i++)
           layer = player.Next();
            while (player!=null)
                sw.WriteLine(layer.Name);
ModyBuchbinder
Hi
Try something like that:
ILayer layer =null;
while ((layer = player.next())!=null) sw.WriteLine(layer.Name);
AhmedEl-Sisi
Can any one help
            StreamWriter sw = new StreamWriter("C:\\temp\\layer.txt"); //Use StreamWriter inside Using statement
            ILayer layer =null;
            for (int i=0;i<map.LayerCount;i++) //Don't loop here
            //You should check layer object not player
Try this, I have also explained what's wrong with your code:
            IMxDocument imx = ArcMap.Application.Document as IMxDocument;
            ILayer layer = null;
            //Get Layers
            //Write Layers To Stream
            using (StreamWriter writer = new StreamWriter("C:\\temp\\layer.txt", true))
                while (layer != null)
                    writer.WriteLine(layer.Name);
Regards,
ababreddy
Thanks Ahmed
