speed problem in OD-Matrix
3604
06-05-2014 03:13 PM
guoliangfeng
My current data does not have the speed field; then I create one.
However, when I use the revised data to create the network dataset, there is some problem when I choose the cost attribute.
Then the results turns out ridiculous: google map shows at least 12 hours travelling while the ArcGIS show only 1 minutes.
I think the problem happens when I choose cost attribute during Network Dataset creating.
What's the correct way to do it?
thanks
MelindaMorang
Can you post a screenshot of the evaluators for your cost attribute?  It sounds like you've either converted units incorrectly, or else some of your network edges have 0 impedance.
guoliangfeng
http://forums.arcgis.com/threads/104307-Need-quot-Drive-time-quot-from-a-Simple-Roads-File-gt-ND
this solves my problem!
still tks a lot
