Find feature class
941
06-03-2014 08:34 PM
PierreWeisse
I work on SDE data bases.
I would list all the entities classes ending in "_OLD".
However in my database SDE I've feature classes and datasets entities.
I would like the script gives a complete list of feature classes ending in "_OLD".
Thank you for your help.
JamesCrandall
See if this helps.  I can't remember exactly where I lifted the original code from.  Probably a quick google search is where I started.
gdb = r'Database Connections\MyDBConnection.sde'
arcpy.env.workspace = gdb
featclsInDatasets = []
for fds in arcpy.ListDatasets('','feature') + ['']:
  for fc in arcpy.ListFeatureClasses('*_OLD','',fds):
     featclsInDatasets.append(os.path.join(fds, fc))
#list the featclasses in datasets
for fc in featclsInDatasets:
    print fc
#list the featClasses not in datasets
for fcmain in arcpy.ListFeatureClasses('*_OLD'):
    print fcmain
edit: ah... I think this is where I originally found the sample: http://gis.stackexchange.com/questions/5893/listing-all-feature-classes-in-file-geodatabase-includin...
