Arcgis runtime content option missing
4807
05-31-2014 07:59 AM
LledSmith
The option to File> Share as> Runtime content is missing from 10.2.03##.  What am I doing wrong?
I have followed the steps at. http://resources.arcgis.com/en/help/main/10.2/index.html#//00660000045q000000
I have done these steps
1. I Opened ArcMap and In the ArcMap main menu, click Customize > ArcMap Options.
2. In the ArcMap Options dialog box, click Sharing.
3. Checked the Enable ArcGIS Runtime Tools check box and click OK.
Then To create Runtime content
1. I Opened ArcMap added a shapefile of the USA save the MXD... reopened it. doubled check that it was still enabled in step 3 above.
2. Then In the ArcMap main menu, click File > Share As > Runtime content is MISSING??? I see three other options but not RUNTIME content.
What am I doing wrong????
DiveshGoyal
From this doc (http://resources.arcgis.com/en/help/main/10.2/index.html#//00660000045q000000) -
To enable the Share As Runtime content menu item
Open ArcMap.
Check the Enable ArcGIS Runtime Tools check box and click OK
MichaelDavis3
Can you check to see if the toolbar tool is available?  I don't recall where it is located off-hand, but I always get to it by searching for "runtime" in the search tool.  I've found it does a better job of exporting than the menu option anyway.
-Mike
LledSmith
No toolbar when I search for it in the Customize.. Commands tab.  Do I need to install something extra like the ArcGIS Runtime SDK for ???WPK??  What does WPK stand for?  I'm using Windows.
MichaelDavis3
Oops - I meant toolbox item, not toolbar item.
DiveshGoyal
Open ArcMap.
