list layers in maps
728
05-22-2014 12:08 PM
stansovern
Hi Folks,
I'm trying to generate a list of maps, and the layers in those maps in python. This script works once, then the line that brings up the path desc = arcpy.Describe(map) will not return a path.  Any ideas?
import arcpy
from arcpy import env
# Loop through all MXDs in the specified folder and list layers in each MXD
folderPath = r"mydata"
env.workspace = folderPath
maps = arcpy.ListFiles("*.mxd")       # makes a list of maps in folderPath
for map in maps:
[INDENT]desc = arcpy.Describe(map)        # make a describe object
mappath = desc.path + '\\'+ desc.file  #build a path to the map
print mappath
lyrlist = arcpy.mapping.ListLayers(mxd)
for lyr in lyrlist:
[INDENT]print lyr.dataSource[/INDENT][/INDENT]
JasonScheirer
Esri Alum
I'm surprised this works at all for you. Describe is not the appropriate function to use here.
Try this:
import arcpy
for map in maps:
    mxd_path = os.path.join(env.workspace, map)
    print mxd_path
    mxd = arcpy.mapping.MapDocument(mxd)
    for lyr in lyrlist:
IanMurray
Honored Contributor
looking at your code
should be
lyrlist = arcpy.mapping.ListLayers(map)
you never create a variable called mxd, you'd probably need to substitute it with your local variable map, as it refer to the map in your list of map files.
stansovern
Awesome Jason, thanks!
