XY coordinates using SQL command
8288
7
05-20-2014 02:54 AM
User35489
Hello There,
Please let me know how to extract the X and Y coordinates from a Feature. Although, we can get it using ArcMAP, but i need it using SQL.
-AS
AsrujitSengupta
I think this should get you the desired X and Y coordinates of the vertices of a feature:
ST_AsText
http://resources.arcgis.com/en/help/main/10.2/index.html#/ST_AsText/006z0000003v000000/
Example:
SELECT OBJECTID, sde.st_astext (SHAPE) SHAPE FROM featureclass_name;
You need to have ST-geometry configured for that Oracle database to use the above query.
VinceAngelo
Esri Esteemed Contributor
You'll need to provide more information, including:
  • The RDBMS you are using
  • The geometry storage format
  • The topology class of the features (point/line/polygon)
Note that not everyone on this forum self-identifies as a "geek", so your
greeting might be considered offensive to some.  I suggest you stick to
less charged terms when requesting help from folks.
- V
User35489
Thanks Vince for correction,
ORACLE 11g R2, ST_Geometry and Polygon feature class.
Best Regards
-AS
- V
VinceAngelo
Polygons have at least 3 unique vertices and a centroid -- Which X,Y value are you
trying to extract? Or do you want them all? And what are you planning to do with
it/them once you have it/them?
- V
User35489
Vince,
We are looking for all.
-AS
- V
AsrujitSengupta
ST_AsText
Example:
VinceAngelo
It might be easier to use ST_PointN to fetch individual points inside PL/SQL
(instead of text processing on a CLOB), which is why I asked what you were
planning to do with them.
- V
User35489
Thanks for your input Vince.
I will try ST_Point also to see the result.
-AS
- V
