Error 000824 - Feature to Point
4310
05-13-2014 10:48 AM
ChristopherBlinn1
I did post in this discussion forum but felt like this was more of a Question/Answer forum post.
ArcGIS for Desktop 10.2.1
Python 2.7
Receiving "Tool is not licensed" error when running this code:
# Import arcpy module import arcpy from arcpy import env import os  # Overwrite pre-existing files arcpy.env.overwriteOutput = True  os.environ['ESRI_SOFTWARE_CLASS']='Professional' #Added based on forum suggestion arcpy.CheckOutExtension('Spatial') #Added based on forum suggestion  Input = "C:\\GIS_DATA\\FGDB.gdb\\InputPolygons" Input_Layer = "Feature_Layer" Output = "C:\\GIS_DATA\\FGDB.gdb\\OutputPoints"  try:    arcpy.MakeFeatureLayer_management(Input, Input_Layer, "", "", "field alias VISIBLE NONE")    arcpy.FeatureToPoint_management(Input_Layer, Output, "CENTROID")  except:    print arcpy.GetMessages()
Result:
Failed to execute. Parameters are not valid. ERROR 000824: The tool is not licensed. Failed to execute (FeatureToPoint).
Never had this issue before.  Migrating update scripts from one version of ArcGIS (10.0 SP5) to another (10.2.1).
Any help appreciated.
by Anonymous User
Not applicable
I have encountered this as well...I think the problem is coming from importing arcpy first. You need to import arcinfo first, otherwise you will start an instance of whatever license you are normally consuming. Try doing this:
import arcinfo
import arcpy
import os
try:
except:
Attempting to change the software class to Professional after importing arcpy will not work because importing arcpy is setting your class key to the current version. Also, you should not need to check out a spatial analyst license for this.
I liked your changing the os environment variable so I tested to make sure this also works:
import os
import arcpy
print arcpy.ProductInfo()
Just make sure to import arcinfo or set the os environment to professional before importing arcpy.
by Anonymous User
Not applicable
import arcinfo
import arcpy
import os
try:
except:
import os
import arcpy
MichaelVolz
Esteemed Contributor
Christopher:
As per Caleb's very informative thread, are you running your script from a lower level version of ArcMap (e.g. your computer is licensed for Basic or Standard) but you are using a professional level license to access the spatial analyst in your python script?
ChristopherBlinn1
IYou need to import arcinfo first, otherwise you will start an instance of whatever license you are normally consuming.
Interesting.. I only use ArcInfo or should I say "ArcGIS for Desktop Advanced" on this particular machine.
Anyways, I am trying your suggestion.  Will post back results soon.
Michael - Sorry didn't see your post when I replied.  I am running the scripts standalone (testing for a batch file).  When using the software, I have always used the Advanced license.  The machine is also an LM, hosting licenses for Basic and Standard as well, but Administrator is set to use Advanced.
Chris B.
ChristopherBlinn1
The fix was adding:
import arcinfo
Thanks for the tips!
