Hi all,I am trying to summarize a field and populate the result in a listview. below is the code of what I am trying to accomplish but with no success. I want it to work as the summarize tool in ArcMap when right clicking the Field to summarize. I am wondering if there is a Select COUNT(fieldName) Group By (fieldName).
Private Sub btnCheckData_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnCheckData.Click
'Load result in the listbox
Dim selectedFieldName As String = Nothing
If cboBoxFields.SelectedIndex <> -1 Then
ListViewDataresult.Enabled = True
selectedFieldName = cboBoxFields.SelectedItem.ToString
ListViewDataresult.Items.Clear()
ListViewDataresult.BeginUpdate()
Dim newlist As ListViewItem
Try
'check if we have the fieldName
If selectedFieldName = Nothing Then
Exit Sub
End If
Dim flayerName As String = cboBoxLayers.SelectedItem.ToString
Dim mxDoc As IMxDocument = My.ArcMap.Application.Document
Dim map As IMap = mxDoc.FocusMap
Dim enumLayer As IEnumLayer = map.Layers
Dim layer As ILayer = enumLayer.Next()
Dim flayer As IFeatureLayer = Nothing
Do While Not layer Is Nothing
If layer.Name = flayerName Then
flayer = CType(layer, IFeatureLayer)
End If
layer = enumLayer.Next()
Loop
If flayer Is Nothing Then
MessageBox.Show("No layer")
Exit Sub
End If
Dim fclass As IFeatureClass = flayer.FeatureClass
'define the cursor to store data
Dim pCursor As ESRI.ArcGIS.Geodatabase.ICursor
'define datastat to query unique values
Dim pDataStats As New ESRI.ArcGIS.Geodatabase.DataStatistics
'define data collection
Dim pEnum As System.Collections.IEnumerator
pCursor = fclass.Search(Nothing, False)
pDataStats.Field = selectedFieldName
pDataStats.Cursor = pCursor
pEnum = pDataStats.UniqueValues
Dim dataStatResult As IStatisticsResults = pDataStats.Statistics
pEnum.Reset()
Do While pEnum.MoveNext
'This part works fine. it will add unique attributes in the listview in the 1st column
newlist = ListViewDataresult.Items.Add(pEnum.Current)
' I wish to have here a number of values that have the same attribute like the summarize in ArcMap, but instead it gives me the total of unique values in the current pDataStats
'here is where I want to add the count of duplicate attributes in the 2nd column
newlist.SubItems.Add(pDataStats.UniqueValueCount)
Loop
ListViewDataresult.EndUpdate()
ListViewDataresult.Refresh()
'MessageBox.Show(statResut.Count.ToString)
Catch ex As Exception
MessageBox.Show(ex.Message)
End Try
End If
End Sub
