python scripting in arcmap 10
542
05-02-2014 03:56 AM
AmalMehdi
Hello
I want to create a python script that do the same as the GO To XY but using a customized user interface. I start to write the interface code and creating the point but I don't know how can I display it in the map. Can you help me please.
Here is the code:
from Tkinter import *
class application(Frame):
    def __init__(self, master):
        Frame.__init__(self, master)
        self.grid()
        self.site_name= Label(self, text= " Site Name: ")
        self.site_name.grid()
        self.site_coordinate =Label(self, text='Site Coordinates : ')
        self.site_latitude= Label(self, text='Latitude: ')
        self.site_longitude= Label(self, text='Longitude: ')
        self.name=Entry(self, bg='white')
        self.latitude=Entry(self, bg='white')
        self.longitude= Entry(self,bg='white')
        self.site_name.grid(row=0)
        self.name.grid(row=1)
        self.site_coordinate.grid(row=2)
        self.site_longitude.grid(row=3)
        self.site_latitude.grid(row=3, column=2)
        self.longitude.grid (row=4)
        self.latitude.grid(row=4, column=2)
        self.ok_button = Button(self,text='Add', command=self.AddPoint)
        self.ok_button.grid(row=5, pady=30)
        self.cancel_button = Button(self,text='Cancel')
        self.cancel_button.grid(row=5, column=2)
    def AddPoint (self):
        latitude_value=self.latitude.get()
        longitude_value=self.longitude.get()
        inPoint = arcpy.Point(longitude_value, latitude_value)
root=Tk()
root.title ("Create Site")
app= application (root)
root.mainloop()
I there is any other possibilities such as using the ModelBuilder or a possiblity to edit the GO TO XY code and customize it please don't hesitate to tell me
Thank you in advance
markdenil
Occasional Contributor III
Tkinter is, it seems, not recomended by esri; it apparently does not play well with ArcMap.
There is a very limited arcpy interface that is available through Arcpy AddIns.
Although limited, it will likely provide what you need.
You will need to download the free addin_assistant.
AmalMehdi
thank you for your answer!
I download the add-ins assistant wizard and I tried to follow step given in Esri seminar in how to create an add-in but I still enable to reach my target
Actually I have to create an add-in that once clicked on display the following interface (see attached photo) and on clicked to add the I have to display the point in the map and store the other enties in a shp file
