Using .format in arcpy.SelectByAttributes Where Clause
1133
04-30-2014 09:11 AM
MikeMacRae
I am trying to pass an integer variable into the where clause of the arcpy.SelectByAttribute tool on an sde feature class to select a record from a "Long" field type.
siteNumber = 324850
SQL_Query = 'NUMBER_ID = {0}'.format(siteNumber)
arcpy.SelectLayerByAttribute_management(Layer, "NEW_SELECTION", SQL_Query)
This does not return any selected records.
If I hard code the query in:
arcpy.SelectLayerByAttribute_management("lyr2", "NEW_SELECTION", 'NUMBER_ID = 391530')
Then it will work.
When I print out my SQL_Query variable, I get
NUMBER_ID = 324850
I've tried:
SQL_Query = "\"NUMBER_ID\" = {0}".format(siteNumber)
SQL_Query = "\"NUMBER_ID\" = '{0}'".format(siteNumber)
SQL_Query = '[NUMBER_ID] = {0}'.format(siteNumber)
and a few other methods, and I still can't get it to return a selected record.
