Multiple Parameters for Python Addin?
2013
04-28-2014 01:50 PM
MikeMacRae
I'm running ArcGIS 10.1 and I'm creating a Python Addin. I'm am wondering if we can have multiple parameters for a python addin tool/button/combobox?
This is what I want to do. I want to create a button that takes 2 parameters the user will choose and zoom to an area of interest.
    The first parameter will have a dropdown where the user chooses one of 2 items. "SITE_A_NAME" or SITE_B_NAME" (These are SDE feature classes)
  • After the user chooses an item, they will manually enter a number (this is a site number. Both of the SDE feature classes have a field called SITE_NUMBER).
    • So, now they have chosen a record in one of the 2 SDE feature classes.
      When they have entered these 2 parameters, I would have them click on a button and the map will zomm to the area.
      I can get the coding down, but I'm not sure if I can set 2 parameters like this?
      JasonScheirer
      Esri Alum
      This sounds like the job for a geoprocessing tool.
      You could just associate the button's onClick with a GPToolDialog call.
      MikeMacRae
      I'm giving that a try. I wanted to see how this works, so I just tried to use the example on the page you provided and tried to create a button that opens the 'Intersect' tool:
      import arcpy
      import pythonaddins
      class OpenGPTool(object):
          """Implementation for Test_Addin_Button_addin.button (Button)"""
          def __init__(self):
              self.enabled = True
              self.checked = False
          def onClick(self):
              pythonaddins.GPToolDialog(r'path to ArcGIS Install\ArcGIS\Desktop10.1\ArcToolbox\Toolboxes\Analysis Tools.tbx', 'Intersect')
      This isn't working. I'm getting the red circle "Missing" icon when I try to open my addin. I thought it might be the path to the tool because it sits in a toolset, so I tried:
      pythonaddins.GPToolDialog(r'path to ArcGIS Install\ArcGIS\Desktop10.1\ArcToolbox\Toolboxes\Analysis Tools.tbx\Overlay', 'Intersect'
      or
      pythonaddins.GPToolDialog(r'path to ArcGIS Install\ArcGIS\Desktop10.1\ArcToolbox\Toolboxes\Analysis Tools.tbx', 'Overlay\Intersect'
      And nothing seems to work.
      markdenil
      You can set any number of variables / parameters.
      First, set a variable to hold each parameter at the head of the ~_addin.py
      just after your imports
      dataType = listOfTypes
      dataField = listOfFields
      dataDate = listOfDates
      dataList = listOfChoices
      theType = 'none'
      theField = 'none'
      theDate = 'none'
      theChoice = 'none'
      now declare each of the variables global inside each class where you want to set or use them.
      for example:
      class ComboBoxClass_DataType(object):
          """Select the data TYPE            """
          def __init__(self):
              global dataType
              self.items = dataType
              self.editable = True
              self.enabled = True
              self.dropdownWidth = '%s' % ('W' * 12)
              self.width = '%s' % ('W' * 12)
          def onSelChange(self, selection):
              global theType
              theType = selection
      Then, in the class behind the 'go' button, access that variable and
      any others the user sets in other wigits
      class ButtonClass_LoadData(object):
          """Implementation for DataBrowser_LoadData.button (Button)
              LOADS the data into the current mxd     """
          def __init__(self):
              self.enabled = True
          def onClick(self):
              global theType
              global theField
              global theDate
              global theChoice
              result = LayerFinder.loadLayerToMxd(theType,
        theField,
        theDate,
        theChoice)
      Dynamically preloading the input lists is an enhancement......
