Solved! Go to Solution.
import traceback try: Your Code Here except: traceback.print_exc() finally: raw_input("Press any key to close this window")
import traceback try: Your Code Here except: outfile = open("error.txt","w") outfile.write(traceback.format_exc()) outfile.close()
A try/except block would do this.
Maybe something along these lines.import traceback try: Your Code Here except: outfile = open("error.txt","w") outfile.write(traceback.format_exc()) outfile.close()
except: traceback.print_exc() raw_input("ERRORS OCCURRED") finally: raw_input("Update Successful")
