Map Algebra statement to interpolate between two rasters
792
6
04-15-2014 03:54 PM
BenRufenacht
I am having some trouble converting a script I wrote for 9.3 to 10.0 using Map Algebra.  It is a linear interpolation between two rasters on a log-linear scale.
Here is the 9.3 code:
gp.SingleOutputMapAlgebra_sa("POW(10 , LOG10(4) - %s * (LOG10(4) - LOG10(10)) / (%s - %s))" %(D25, D25, D10), X25, "'';''")
and here is what I have for 10, which does not work:
X25 = Power(((Log10(4)) - Raster("D25") * (Log10(4) - Log10(10)) / (Raster("D25") - Raster("D10")),10)
X25.save(ws + "\X25")
Does anyone have any suggestions on what I may be doing wrong?
NeilAyres
What doesn't work, what's the error message?
You may want to try a double "\" when you save the output.
JamesCrandall
MVP Frequent Contributor
I am unsure if your Power() method is properly formed.
http://resources.arcgis.com/en/help/main/10.1/index.html#//009z00000097000000
It takes two parameters but it doesn't look like you are supplying these.
Power (in_raster_or_constant1, in_raster_or_constant2)
Also, I noticed that there is an extra "(" paren char:
BenRufenacht
This is the very descriptive error I am getting:
<type 'exceptions.RuntimeError'>: UNKNOWN
I tried the double "\\" and it did not make a difference.
I should note that I simplified my equation just to test the map algebra and I was able to get a simple raster addition to work and save.
BenRufenacht
My first parameter is the map algebra statement and the second is the constant 10 to cancel out the log interpolation result.
Thanks for pointing out the extra "(".
BenRufenacht
Now I am thinking that my map algebra is fine.  I think my issues may be in how I am stetting the environmental variables.  Here is more of the script:
# Import system modules
import arcpy, sys
from arcpy.sa import *
# Check out the ArcGIS Spatial Analyst extension license
# Set workspace from input
ws = sys.argv[1]
db = sys.argv[2]
arcpy.env.workspace = db
arcpy.env.scratchWorkspace = db
# Set input rasters
D10 = sys.argv[3]
D25 = sys.argv[4]
D50 = sys.argv[5]
D100 = sys.argv[6]
D500 = sys.argv[7]
# Set environment variables from input rasters
arcpy.env.snapRaster = D10
arcpy.env.extent = D10
arcpy.env.outputCoordinateSystem = D10
cord = arcpy.env.outputCoordinateSystem
arcpy.env.cellSize = D10
cs = arcpy.env.cellSize
# 10 and 25 Log-Linear Interpolation
#X25 = ws + "\Calc1.gdb\X25"
X25 = Power((Log10(4)) - Raster(D25) * ((Log10(4) - Log10(10)) / (Raster(D25) - Raster(D10))),10)
Anyone see anything wrong here?
BenRufenacht
I was able to get it working with the following code:
import arcpy
ws = arcpy.GetParameterAsText(0)
db = arcpy.GetParameterAsText(1)
arcpy.env.workspace = ws
# Set input rasters
D10 = arcpy.GetParameterAsText(2)
D25 = arcpy.GetParameterAsText(3)
D50 = arcpy.GetParameterAsText(4)
D100 = arcpy.GetParameterAsText(5)
D500 = arcpy.GetParameterAsText(6)
arcpy.env.snapRaster = r"D10"
arcpy.env.extent = r"D10"
arcpy.env.outputCoordinateSystem = r"D10"
#cord = arcpy.env.outputCoordinateSystem
arcpy.env.cellSize = r"D10"
#cs = arcpy.env.cellSize
#arcpy.env.overwriteOutput = True
# 10 and 25 Log-Linear Interpolation Map Algebra
