Register view as a layer to use in GeoProcessing tool
1074
04-03-2014 05:50 AM
MichaelBlom
Hi there,
In the past, there was the command line tool "sdelayer -o register" and I could register a view as a layer.
From what I read in this blog posting http://blogs.esri.com/esri/supportcenter/2013/10/04/do-this-not-that-alternatives-to-using-sde-comma..., instead of using "sdelayer -o register ...."
If needing to take advantage of geodatabase functionality, you can register the feature classes/tables with the geodatabase, which will also registers them with the ArcSDE system tables during the process.
So I used this register with Geodatabase tool, and apparently "views are not supported".
Help please me with registering my view as a layer if you can.
Mike
VinceAngelo
Esri Esteemed Contributor
Views cannot have SDE-set rowid columns, and are therefore not eligible for
geodatabase registration.  They are supported as simple feature classes if
the geometry column is registered with ArcSDE via 'sdelayer -o register'.
- V
MichaelBlom
If I right click on the view, I can see there is an option to Manage-> Register with Geodatabase, but this is greyed out
Is this because views are not supported?
VinceAngelo
- V
MichaelBlom
...which I exactly what I ended up doing... breaking out the old command line tools.
