Error: reading a geodatabase on a device
4168
10
03-25-2014 02:30 AM
TorstenStruck
I'm coding a small application (with SDK for iOS 10.2.2) for displaying an offline geodatabase that I have created with ArcGIS for Desktop 10.2.1. I have put the geodatabase into my application bundle and everything looks good on the xcode ipad simulator.
But on my "real" ipad I'm getting the following error message when creating the AGSGDBGeodatabase object:
Error Domain=com.esri.arcgis.runtime.error Code=6 "PRAGMA journal_mode = WAL;" UserInfo=0x170264bc0 {NSLocalizedDescription=PRAGMA journal_mode = WAL;}
Here's the code snippet for loading the geodatabase file (ltg.geodatabase):
   NSString *gdbPath = [[NSBundle mainBundle] pathForResource:@"ltg" ofType:@"geodatabase"];
   NSError* myerror;
   AGSGDBGeodatabase *gdb = [[AGSGDBGeodatabase alloc] initWithPath:gdbPath  error:&myerror];
Any ideas or solutions?
Thank you!
SuganyaBaskaran1
Thanks for reporting. This seems to be an issue in the SDK. We'll work on fixing it.
A work around for it is to use iTunes File Sharing and share the geodatabase through it.
To enable file sharing in your app, set the property "Application supports iTunes file sharing" to YES in Info.plist file. Then you should be able to add the geodatabase as described here
You can then create the geodatabase as follows:
NSArray *paths = NSSearchPathForDirectoriesInDomains(NSDocumentDirectory, NSUserDomainMask, YES); NSString *gdbPath = [paths objectAtIndex:0]; gdbPath = [gdbPath stringByAppendingPathComponent:@"ltg.geodatabase"]; if ([[NSFileManager defaultManager] fileExistsAtPath:gdbPath]) {    //create GDB here }
Hope this helps, please let us know if you have more questions.
SuganyaBaskaran1
ShiminCai
Occasional Contributor III
I bundled my geodatabase with my app. When my app started I copied the geodatabase from the app bundle to the app's Documents folder and then created the gdb from the copy in the Documents.
TorstenStruck
Thank you! That worked fine!
  //create GDB here
SweetySingh
Which file type got worked .gdb or .geodatabase?
We are also facing same problem i.e unable to read data from .gdb file.
How we have to add it : locally in app or in documents directory?
Can you help with the steps how it got worked for you?
Sweety
SivaVysyaraju
I think it is .geodatabase file.
SuganyaBaskaran1
It's the .geodatabase file. Are you creating the file as outlined here ? This gives a .geodatabase file which you can add to the app through file sharing
VIKRANTKRISHNA
New Contributor III
I need to package a demo geodataset along with app. How can I make this work, having geodatabase as part of project doesn't seems to work.
YueWu1
by Esri Regular Contributor
Hello Vikrant,
Use this line to load the local geodatabase:
[PHP]NSString *gdbPath = [[NSBundle mainBundle]pathForResource:@"gdb_file_name" ofType:@"geodatabase"];[/PHP]
This is a generic way about how to load a file from Resources folder in iOS:
http://www.android-ios-tutorials.com/257/read-files-in-resources-folder-ios/
Hope this can help.
VIKRANTKRISHNA
New Contributor III
Nathan,
           This seems to be work for simulator, for iPad its giving error Domain=com.esri.arcgis.runtime.error code=12 "automatic extension loading failed:"
