Exception calling DataServerManager.Connect
1063
03-21-2014 11:45 AM
JonathanBailey
Using the code samples provided by Esri, I'm trying to connect to a SQL Server instance using the DataServerManager class. Following is the entirety of my code in a .NET console application:
using System;
using ESRI.ArcGIS.DataSourcesGDB;
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS;
namespace ConnectToSQLServer
    class Program
        static void Main(string[] args)
            try
                RuntimeManager.Bind(ProductCode.Engine);
                IAoInitialize aoInitialize = new AoInitialize();
                aoInitialize.Initialize(esriLicenseProductCode.esriLicenseProductCodeEngineGeoDB);
                IDataServerManager dataServerManager = new DataServerManager();
                dataServerManager.ServerName = "MONTREAL\\SQLEXPRESS";
                dataServerManager.Connect();
                if (dataServerManager.IsConnected)
                    Console.WriteLine("DataServerManager is connected.");
                else
                    Console.WriteLine("DataServerManager is not connected.");
            catch (Exception exception)
                Console.WriteLine(exception.Message);
            finally
                Console.ReadLine();
When dataServerManager is called, the following exception is raised:
-  exception {"A syntax error occurred trying to evaluate a query string (Exception from HRESULT: 0x80040203)"} System.Exception {System.Runtime.InteropServices.COMException}
Any ideas?
Jon.
