TOC - totally stumped
4869
03-19-2014 01:38 PM
CM2
Hey folks,
I've been trying to use Nliu's TOC today. I've followed a few examples and looked through the threads here, but I'm totally stumped on why my code isn't working.
I was wondering if anyone might want to take a look at it here:  http://jsfiddle.net/Tx4R6/4/
My service is definitely working. It contains one layer. You can substitute any known service, but while the service shows in the map, it does not show in the TOC.
I've made sure the dijits/functions are called in the correct order. I've seen other examples use the online source for AGSJS so I can't see how that's an issue.
Any ideas? Thanks for reading!
JohnGravois
hi Craig, welcome to our forum!
its your event listener.
map.on('layers-add-result', function(e){
this only gets called when you use the method map.addLayers([layer]);
since you're using map.addLayer(layer); you need to listen for 'layer-add-result' instead
JohnGravois
CM2
Unbelievable!  You're the man, John.  I appreciate that very much.  It's the little things with stuff like this.
Totally working and a fantastic widget.
Thanks again.
JohnGravois
no sweat.  please consider marking this thread as 'answered'
